跳转到主内容
工具
配件
没有特定配件。
  1. 手机在usb-c的针脚上检测到的了不应该有的电阻. 如果充电口上有水或者湿度太高,就会引发警告/警告声,并且停止充电.
    • 手机在usb-c的针脚上检测到的了不应该有的电阻. 如果充电口上有水或者湿度太高,就会引发警告/警告声,并且停止充电.
    • 插充电线时检查是否有水.
    • 盐水和含氯的溶液对接口都是有损害的千万不要用这样的插头充电. 清洁插头并且让插头干燥,这可以救你的手机和充电器一命.
  2. PC 笔记本电池
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  3. 解决此问题的步骤:
    • 解决此问题的步骤:
    • 1. 用压缩空气轻轻的往插孔里吹起来吹走水和一些小碎屑. 也可以用吸管直接向插孔里吹气.
    • 2 . 用干净的水和切成细条状的纸巾清洁插孔. 轻轻的滴水到插孔里, 再用条状纸巾把水吸干.
    • 3. 风干: 充电之前需要放置六个小时让水干透,这段时间你也可以使用你的手机但是不可以充电.
    • 如果你急需充电,可以使用无线充电 (S9+)
    • 注意充电头也可能被电解质污染或者生锈,因此必须也按照上述方向小心清理 . 不然可能会污染手机充电口再次导致问题. 也可能在连接手机的时候出现上述问题.
结论
不要用潮湿的充电器插头充电.
3等其他人完成本指南。
特别感谢这些译者︰
50%
Glitch正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Carsten Dahl Hjarup
于2013年11月04日注册
1,014 信誉积分
创作了3篇指南
The alert go away on its own, when the connector issue is not present anymore.
However it is strongly suspected that the same mechanism is active inside the phone, so it screen is broken
or the sealing on the phone is not working anymore - it could be moisture inside the phone that cause the issue.
If this happens, I would leave phone on a heat source (radiator etc.) to dry out , at about 30-40 DEG C.
If someone have more info or experience on this topic, please leave in the comments :o)
Carsten Dahl Hjarup - 回复
I have a S9, it is showing the moisture problem and my battery is dead, can not charge it, I live in Zambia and do not have an Samsung repair shop close to me, is there anything else I can do to fix?
Christo Deysel - 回复
same did you fix the issue?
RadiusThinker -
It is showing the blue droplet when inserting the charger and also to remove the charger, and it was not in contact with any liquid at all.
Christo Deysel - 回复
Christo, you can always charge your phone with wireless charger. My gf is having the same issue but she can charge with a wireless charger!
Shaikh Shiban Qureshi - 回复
添加评论
浏览统计数据:
过去的24小时: 1,395
过去的7天: 3,028
过去的30天: 17,863
总计 97,376
