简介
使用本指南拆开或更换三星Galaxy S7中的NFC天线和无线充电线圈。
本个指南涉及到拆开玻璃后盖。您将需要更换胶粘剂,以重新安装玻璃后盖。
你所需要的
当玻璃后盖没那么烫的时候,尽可能靠近手机被加热的边缘使用吸盘,同时避开曲面玻璃边缘。
往上提起吸盘,然后往玻璃后盖和中框的缝隙中插入撬片。
Because of the metal lip around the phone the picks were to thick to get under the glass. Couldn’t get the glue loose enough with the iOpener or the glass lifted high enough with the suction cup despite using a lot of heat and stength on the suction. Ended up having to use a thin piece of metal to get the first separaration. After that the picks are ok to use.
This step is certainly giving me trouble. I don’t have enough hands to be able to both form the space and to insert the pick. In order to even form the space, I need to use the double-sided plastic scraper-thing.
Turns out that three hands was the answer. I had my dad insert the pick while I pried open a gap, and it was smooth sailing from there.
How do you pull on the suction cup? I.e. what's the right technique to pull up the suction cup? Just pulling up is going to lift the entire phone, unless I had some kind of double sided suction cup up keep the phone stuck to the table.
Thank you
I'm going to try it Jerry rig everythings technique. https://m.youtube.com/watch?v=kHzmFPoZbC... unfortunately every iFixit video seems to use the clamp which seems like an oversight for a tutorial. But it is not fair for me to be too annoyed since they have really good repair kits and the repair guides are nice.
A X -
一旦将撬片插入到玻璃的缝隙中,重新加热并放置iOpener以软化胶水。
Use a heat gun or hair dryer to soften the adhesive to remove the back cover. The Iopener that you heat up with the microwave takes a very long to accomplish the same task.
Keep the heat gun in motion at all times and check the surface temperature of the phone with your hand every few seconds to ensure it does not overheat the plastic and glass and electronics. Use several blue guitar picks to brake the seal of the cover once you have softened the adhesive and popped the seal initially with the suction cups.
对手机剩下的三侧边缘,并重复之前的加热和滑动步骤。
在每一个已经划开的边缘放一个撬片以防止胶水重新粘合。
At about this stage, as I was working on the fourth side, the layer of black paint on the inside of the glass started to separate from the glass, near the edge. I may have overheated the phone (I used a heat gun). Most of the paint layer ended up left behind, attached to the body of the phone, as the glass came away - along with the lens covers of the camera and flash. I removed and discarded as much of the paint as I could using tweezers, a spudger, and cautious heating with the heat gun. I hope the back glass will work OK without it; a clear back cover will be a distinctive design feature! If not I’ll have to get a new one. (Note, some battery repair kits from other suppliers such as Amazon include a replacement back glass, which would help with this issue).
Hi Michael,
The glass back would definitely work without the black paint. In fact, there are tutorials online that instruct exactly how to do that in order to have a cool transparent glass back look!
如果要用异丙醇清洁中框表面,请注意不要在无线充电线圈上沾上任何酒精。如果线圈涂层接触酒精,则会破裂。
Do not hold the glass as shown. I did that, and the glass cracked when I tried to pull the adhesive because the adhesive was on tight. Always keep the glass down on a flat surface so that you don’t apply any bending forces to it.
I'm sorry to hear that! That's a good suggestion—I'll modify the photo slightly to deter people from holding the glass in the air.
拆卸12个3.5毫米菲利普斯螺丝。
They made a typo I think its supposed to say 1.5 millimeter instead of 3.5 millimeter.
QA sticker over screw on my model (2018). I advise you delicately remove these with something sharp, from the center of the screw outwards. If you stick the screwdriver straight in, the sticker will jam up in the head of the screw and make it much less likely to get a good grip on the screw as it turns, causing it to slip and strip the screw head.
要重新组装您的设备,请按相反的顺序执行这些步骤。
4等其他人完成本指南。
由衷感谢以下译者:
85%
Enrico Shan正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
9条评论
this is perfect
Can you help me with videos ?
Does this also replace the charging port itself?
Hi Adam, this guide is not for replacing the charging port—the charging port is part of a separate assembly that requires further disassembly to remove.
Wireless charging stopped working today on my S7 which is out of warranty. Do you know if this wil solve the problem or do I need to tackle it another way?
Without seeing the phone it’s hard to say what the problem is. Replacing this assembly will likely fix any hardware issues related to wireless charging, but won’t help if you have a software issue. It’s probably worth trying a factory reset and looking in to other troubleshooting methods before you open the phone.
If I were to replace my battery from one from iFIXit, will that battery support wireless charging or no? How would be able to go about making it be a wireless charging one?
It would have helped immensely if you would have removed the assembly out of the phone to show us what it looks like.
I used a heat gun and heated it a little too much. The color of the rear glass is just a sticker on a clear cover. Due to this I tore the sticker off. Now the back cover is see through, which isn’t a bad thing but the repair was for a customer.
Kevin Bishop - 回复
When using the iOpener, you may need more than 30 seconds, especially in compact or low wattage microwaves. Take this slowly, though, and be extremely careful, as it is easy to overheat your iOpener. Remember, you can always heat it up a tad more, but you cannot undo overheating it.
Jacob Pratt - 回复
I used an adjustable heat gun and set it to 400 degrees (F). That was enough to seperate the glass without having to worry about exposure times of the heat. The front of the phone was just fine. Just be ready to use a bunch of picks to slide in between because they will be needed this way.
Ryan Schumerth - 回复
I went from the bottom center up, using one ifixit tools, one suction cup and one pick.
Pick just popped in with some minor pressure.
Laid heat pack along base of phone 2 mins first and worked up slowly, rotating picks as I went. Had to heat iopener over several 30 second bursts
Lauren Burt - 回复
This is useless because the phone does not recognize the new battery and will behave like on the old one
Search for “battery count xda"
Albert Einstein - 回复
That is an interesting discovery! Thanks for pointing it out—I’ll have to look into it.
Even if this is true, replacing the battery should still give restore a significant amount of life, since the max voltage affects a minor amount of the battery’s capacity. If you charge a worn battery and a new battery to the same lower max voltage, the worn battery’s voltage will dip more under use and will be depleted faster.
Arthur Shi -
Thanks for the guide! It helped me replace a friend's battery with no problems!
Darren Crook - 回复
I will never replace a screen again, and don’t recommend it. Not for phones nowadays. Once upon a time everything was screwed together, and you might even get the same quality or better screen when buying from eBay. And having the phone repaired was nearly the cost of the phone. Now, it’s the reverse. Removing the glued back and screen and cleaning off all the glue for a clean re-seal is an ordeal that takes multiple hours, AND, often the screen you buy on eBay is NOT OLED, but an LCD, and a blurry one at that. And the local phone repair store will replace the screen with an OLED, reliably, same day turn around, for not much more than the cost of an actual OLED screen, because they have the parts in bulk, and the tools and experience to do it quickly. Never again!
domarius - 回复
have you ever had one that just wont open at all? i can not get mine to open to replace the battery i have heated with a heat gun and attached suction cup and it will not lift at all
Carla James - 回复
Hi Carla,
I've definitely had that experience before. The adhesive is very strong, and the curved back makes getting the initial seam very difficult. I'd suggest focusing on one small area on the edge. Apply steady force when you pull, and repeat a few times to loosen the adhesive. Eventually it will give and present a small gap.
Arthur Shi -
