跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
三星 Galaxy S7 Edge 电池更换
你所需要的
  1. 三星 Galaxy S7 Edge 电池更换, 后壳玻璃: 步骤 1 中的图像 1,1
    • 拆开你的手机会破坏防水密封。在你拆解之前准备好替代的防水胶;或者不粘替代的防水胶,并且在重装后的使用过程中小心避免沾上液体。
    • 加热一个iOpener并且把它放在手机长边上约2分钟。
    • 你可能需要重新加热并且重新放置iOpener几次来让手机足够热。遵照iOpener的指南来避免过热。
    • 吹风机、加热枪或加热盘也可以使用,但是要小心,注意避免手机过热——OLED屏和手机电池都容易因为过热而受损。
  2. 三星 Galaxy S7 Edge 电池更换: 步骤 2 中的图像 1,1
    • 用手摸背板已经热了之后,在版面上靠近已加热的边缘处安装一个吸盘,越靠近越好,但要避开曲边。
    • 吸盘在曲边上吸不住。
    • 如果玻璃背板已经碎了的话,吸盘可能吸不住。尝试用强力胶带来拉起背板或者用胶水把吸盘粘在背板上,这样你就可以继续了。
    • 抬起吸盘并且在玻璃板缝隙处放入一个撬片。
    • 由于玻璃曲面的关系,你将会向上推,而不是与手机平面平行推撬片。
    • 如果在此步骤遇到了问题,再加热让胶软化,然后再次尝试。胶水冷却地非常快,因此你可能需要重复加热它。
    Suction cup does not seem to work.
    Wincess Gentius - 回复
    Makes it sound ridiculously easy, when in reality you have to be pulling with tons of force while also holding the phone down and on top of that you have to insert the pick in a relatively small amount of time.
    Rodrigo Morgado - 回复
    I was getting no where with the iOpener and picks alone, so I followed a YouTube video and used the iOpener as well as a hairdryer. I had to make the first cut in the ahesive with a utility/razor knife, then as soon as I was through the first part I inserted the plastic picks. The back of the phone has to be too hot to touch, ideally all around, so the iOpener alone is not enough.
    Mark Frost - 回复
    Thanks for the above comments. I was also getting nowhere with the iOpener then used a hairdryer on the non-camera end until it was hot to the touch and managed to get a Stanley knife into the gap and lifted enough to get a pick in. Plain sailing from there with patient heating and working the picks in to cut the glue. Eventually success and the back came off.
    Alastair - 回复
  3. 三星 Galaxy S7 Edge 电池更换: 步骤 3 中的图像 1,1
    • 一旦你把撬片确实地插入了玻璃重新加热并且重新放置iOpener来软化封胶。
  4. 三星 Galaxy S7 Edge 电池更换: 步骤 4 中的图像 1,2 三星 Galaxy S7 Edge 电池更换: 步骤 4 中的图像 2,2
    • 沿着开口滑动撬片,打开防水胶。
    • 动作慢一些这样撬棒的尖端才不会滑出缝隙。如果滑动困难,重新加热并放置iOpener。
    • 把撬片留在缝隙里然后取第二个撬片来进行下一步。把撬片留在里面可以防止胶重新粘在一起。
  5. 三星 Galaxy S7 Edge 电池更换: 步骤 5 中的图像 1,3 三星 Galaxy S7 Edge 电池更换: 步骤 5 中的图像 2,3 三星 Galaxy S7 Edge 电池更换: 步骤 5 中的图像 3,3
    • 在剩下的三边都重复之前的加热和滑动撬片的动作。
    • 在划完每一边之后都留下一个撬片,以阻止胶重新粘在一起。
  6. 三星 Galaxy S7 Edge 电池更换: 步骤 6 中的图像 1,2 三星 Galaxy S7 Edge 电池更换: 步骤 6 中的图像 2,2
    • 提起玻璃把它从手机上移走。
  7. 三星 Galaxy S7 Edge 电池更换: 步骤 7 中的图像 1,2 三星 Galaxy S7 Edge 电池更换: 步骤 7 中的图像 2,2
    • 重装后壳:
    • 首先用镊子揭掉后盖和手机后框上残留的胶。
    • 然后,用高浓度(至少90%)异丙醇和不起毛的布来清理粘胶的部位。擦的时候只向一个方向擦,不要来回来去地擦。这能让表面更适合新的胶来粘合。
    • 在重新粘合新的后盖前请确保你的手机可以正常开机。
    • 新的胶应该是预裁切在塑料片上的,如果你没有那种胶,亦可使用如Tesa 61395这样的液体强力胶水,但请注意此种胶水可能会在粘合后盖后透过其他微小缝隙或留下痕迹。
    • 在安装完毕后,你可以将手机置于一摞书下来形成均匀的压力使新的胶附着良好。
    • 如果你想的话,你也可以用旧有的胶粘回后盖。去掉可能会妨碍后盖整齐粘回原位的大块胶。在安装完成后,加热后盖然后加压来让后盖粘牢。请注意,这样你的手机将不会防水,但是旧的胶一般也足够使后盖粘牢。
  8. 三星 Galaxy S7 Edge 电池更换, NFC 天线和充电线圈组件: 步骤 8 中的图像 1,1
    • 拧下如图的12个3.5mm螺丝。
  9. 三星 Galaxy S7 Edge 电池更换: 步骤 9 中的图像 1,2 三星 Galaxy S7 Edge 电池更换: 步骤 9 中的图像 2,2
    • 利用上部天线左下的凹槽来把它撬出手机。
    • 移除上部天线。
  10. 三星 Galaxy S7 Edge 电池更换: 步骤 10 中的图像 1,1
    • 从手机上抬起并移除无线充电线圈。
  11. 三星 Galaxy S7 Edge 电池更换, 扬声器组件: 步骤 11 中的图像 1,1
    • 从手机上抬起并移走扬声器组件。
  12. 三星 Galaxy S7 Edge 电池更换, 断开电池连接: 步骤 12 中的图像 1,2 三星 Galaxy S7 Edge 电池更换, 断开电池连接: 步骤 12 中的图像 2,2
    • 用撬棍平的一边来断开电池接头的连接。
  13. 三星 Galaxy S7 Edge 电池更换, 电池: 步骤 13 中的图像 1,1
    • 准备好 iOpener 直接将它用于电池上
    • 或者,在电池的每个角落下涂抹一些异丙醇,并让其作用几分钟以帮助减弱粘合剂。
  14. 三星 Galaxy S7 Edge 电池更换: 步骤 14 中的图像 1,2 三星 Galaxy S7 Edge 电池更换: 步骤 14 中的图像 2,2
    • 用撬片从底部撬起电池。
    • 你将会抵着主板和天线正上方的盖子进行撬动。小心地撬,以避免损伤这两样器件
    • 你可能需要重复地重新加热和安放iOpener以进一步软化胶。这种胶很难搞,可能几次尝试才能把撬片放到电池下面。
    • 在此过程中尽量不要让电池变形。损坏的软包锂电池可能会泄漏危险化学品,着火甚至爆炸。不要过多施力或用金属工具撬电池。
    I used propanol to soften the glue and it worked well. Every time I lifeted the battery a bit (you can hear the glue tearing) I added a few more drops of propanol. Be careful, the heat sink is below the centre of the battery, and I scratched mine a bit as I levered against it.
    Mark Frost - 回复
  15. 三星 Galaxy S7 Edge 电池更换: 步骤 15 中的图像 1,2 三星 Galaxy S7 Edge 电池更换: 步骤 15 中的图像 2,2
    • 沿着电池缝隙划动撬片来打开残余的胶。
  16. 三星 Galaxy S7 Edge 电池更换: 步骤 16 中的图像 1,2 三星 Galaxy S7 Edge 电池更换: 步骤 16 中的图像 2,2
    • 把电池抬出壳子。
    • 移除的电池不要重复使用,因为重复使用是一种潜在的安全危机。用新电池来代替它。
    • 为了安装新电池:
    • 从手机上去除残留的胶,然后用异丙醇和不掉毛的布清除粘电池的部位。
    • 用预切开的胶或是双面胶固定电池。为了准确固定位置,要把胶直接粘在手机里而不是电池上。胶应该粘在电池仓边缘周围而不是中间的正方形切割部位(那其实是屏幕的背面)。
    • 实力按压电池入位5-10秒。
结论
按相反的顺序组装设备。
完成本指南后请校准你新安装的电池
127等其他人完成本指南。
由衷感谢以下译者:
en zh
62%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Arthur Shi
于01/03/18注册
249,840 声望
创作了503篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,732篇指南
12条评论
EXCELLENT TUTORIEL CLAIR ET PRECIS…….reussite du remplacement de la batterie ENCORE MERCI
daberalem - 回复
Super Anleitung und super Werkzeug! War in 45 Minuten mit allem fertig und bin begeistert!
Lars Gang - 回复
How.. in the bloody !&&*.. do you use the battery adhesive? Don’t just stop with the removal. Reapplication of the adhesive is an IMPORTANT STEP!
Doug Weber - 回复
Hi Doug,
I’ve written up a short guide for the battery adhesive. You can find it here. It’s now added into the last step. Hope that helps!
Arthur Shi -
1-2 hours…acturally about 30 mins! excellent tutorial
Sean Celestine - 回复
Thanks for this guide changed my S7 Edge battery without a problem feels like its new again.
mcvll - 回复
How do you replace battery with the waterproof feature still possible?
Ancient Sniper - 回复
Received the package before the delivery date. Very neatly packed and good instructions. Hopefully, the battery will last a while…
Raveena Lal - 回复
How do you reattached the battery connection? The replacement battery won’t fit. I can snap the old battery back in but the new battery is very loose and keeps popping free.
Damion Waltermeyer - 回复
An important question: if i replaced the S7 Edge battery with the S7 one is there any possible issue? I plan to change it as soon as possible but I want to better understand if there can be any issue with the phone.
Andrea Canidio - 回复
I had problems! I came across your post after the repair was complete! You gave more information than the YouTube videos I was using! I struggled removing the battery since it was oversecured with glue! And I kept powering the phone back on by accident pushing the side switch during reassembly! And I got the back of the phone on but not watertight! I feel like I should have used some blue for the back, but didn't have any on hand! But it's together and working! There were better ideas from your article that would have made it less painful for me!
David Dunn - 回复
Thank you for a great, clear guide. Great kit from iFixit too including tools and new battery.
The only tricky part was getting the back off. Ditched the iOpener and used a hairdryer (left comment on that section). Once the back was off, took about 30 mins to dismantle, replace the battery and reassemble. Confirmed all working properly then used some B7000 glue to secure the back. Done and phone life extended another few years. Excellent.
Alastair - 回复
添加评论
浏览统计数据:
过去 24 小时: 28
过去 7 天: 192
过去 30 天: 823
总计 127,106
