简介
不确定如何处理后盖套装中的所有胶带?那你就来对地方了!本指南介绍了如何使用带玻璃后盖(S7和更高版本)的 Galaxy S 系列后盖粘合剂套装。它还包括有关如何转移和安装各种后盖组件(例如,后挡板和指纹传感器)的说明。
''你可能不需要使用套装中随附的所有胶带。如果要转移指纹传感器,则可能需要一些双面胶带,例如Tesa胶带。
有关 Galaxy S 手机的胶带列表,查阅这个链接。
当粘贴这样的胶带时,以下是一些一般性提示:
- 通常,胶带的一面是彩色的,一面是非彩色的(纸或透明塑料)。无色的一面决定将胶带首先应用于哪个表面。
- 为了使粘贴操作更容易,你可以将未撕开的胶带对准手机上的预期位置,然后用胶带将一条边向下固定以将条带固定到位。这将使你能够撕下塑料衬里并露出粘合剂一边而不会失去准确度。
通过使胶粘带的轮廓与胶粘剂残留物和电话框架相匹配,找出支撑带如何与表面对齐。
使用打开工具和高浓度异丙醇清除手机框架上的所有残留胶。
如果要重新使用后盖,请清除后盖上的所有残留粘合剂。
63等其他人完成本指南。
特别感谢这些译者︰
95%
Yuting Zhao正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
10条评论
The flex cable for the fingerprint sensor is so short and delicate that it’s fiendishly difficult to locate and snap in. You only have a very narrow gap between the back cover and the phone, it wants to jump out of position if you misalign at all, and you can’t reach under there with normal size fingers. Not only that, it’s done with the rear cover adhesive in place so if that touches, it sticks.
I got it snapped on, and the flex cable broke at the same moment. So, no fingerprint sensor for me. Also, the new back cover arrived broken. If it was usable, the way to do it IMHO is to attach the flex cable first, then push the fingerprint sensor assembly on to the new back cover adhesive (it goes on from behind), then close the back cover.
Hey William,
If you bought the back cover from iFixit, please contact our support team here and we will get a replacement sorted out for you!
P.S. I got the battery and cover because the old cover was warped and separated, figured may as well replace the battery in a 2-year-old phone. Turns out, the battery was swollen and huge and it had pushed the back cover open. Not a good situation. So if your back cover is coming off, suspect that battery.
P.P.S. The fingerprint sensor flex cable connector probably could be manipulated into position with the tweezers from the tool kit and pressed down into place with the plastic screwdriver thingy, Just hover the back cover over it with your third hand (or a helper).
Will the phone still be water-resistant after this repair?
