简介
使用本指南移除或更换三星 Galaxy Note20 Ultra 的后盖。
为了你的安全,在拆卸手机之前,请将电池放电至 25% 以下。这可以降低在维修期间电池意外损坏时发生危险热事件的风险。如果你的电池膨胀,采取适当的预防措施。
你所需要的
沿着后盖的三个剩余侧面重复加热和切割粘合剂的过程。
继续操作时,在每个角落留下一个撬片,以防止粘合剂重新密封。
在手机的整个周边来回滑动撬片,以切割任何丢失的粘合剂。重新加热任何顽固的粘合剂。
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
要重新组装你的设备,请按照逆序执行这些说明。
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商。
维修没有按计划进行?尝试一些基本故障排除,或询问我们的[链接|https://www.ifixit.com/Answers/Device/Sa...|Samsung Galaxy Note20 Ultra 论坛]寻求帮助。
7等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6条评论
Clean the rim of the phone off and when you get the new backplate use adhesive it came with if it did not come with adhesive. use Double-Sided High Strength Polyester Tape 300LSE (3MM x 25M) (3M Model # 9475LEB) or something similar to it(don't use liquid glue, you will mess stuff up)
everything went great and everything works well. it only rattles a little. like something small is loose. I don't know if that's bad now?
I had to remove a small part from the old back and put it on the new one.
So to do this in reverse you use the picks again do you heat it Last to get the adhesive to adhere????? The Title is very misleading it says replacement as far as any manuals I have seen (IE cam replacement, Head replacement (Automotive) the instructions do not stop once it is removed they have a Butt load of specific steps to reinstall the item, like Torque specs, Timing alignment )Not this to Reassemble do the steps in reverse order as this states . It should be called Removal only. Is there special glue used? What about the camera cover thing does it get attached to the rear Glass/Cover or is it attached to something internally?? No mention of that at all Very crappy Instructions to be honest
