简介
使用本指南可拆卸或更换Samsung Galaxy Note10上的屏幕。
由于Note10的设计,你必须卸下后面板才能断开屏幕电缆的连接。
在开始此过程之前,请确保后面板和屏幕都有一套替代粘合剂。
你所需要的
将第三个三角撬片插入手机顶部边缘的缝隙中。
将三角撬片滑动到右上角,将粘合剂切成薄片。
将三角撬片插入右上角,以防止胶粘剂重新密封。
向上倾斜金属屏蔽罩,以便可以用手指抓住它。
向上剥开无线充电线圈,使其远离设备。
卸下无线充电线圈。
is it possible to replace with brand new wireless charging coil
Why do you want to do so?
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
要重新组装设备,请按逆序执行上述步骤。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些[[修复后的问题|基本故障排除],或向我们的社区寻求帮助。
要重新组装设备,请按逆序执行上述步骤。
32等其他人完成本指南。
由衷感谢以下译者:
96%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
Does the same method apply to Note 10+ as well ?
The method is similar but not identical. We will have Note10+ guides up within this month!
Would the phone still be water resistant?
Depending on adhesive you use to put back glass
For anyone thinking about doing this -
The screen on my wife’s Note 10 cracked. She lived with it for a little while, but of course the cracks spread and got worse over time. We decided to take a stab at fixing it ourselves.
From what I can tell, the instructions here are spot on. I was eventually able to fix the phone myself - looks brand new. You definitely don’t have to be a rocket scientist to do this - just some patience while you go through the steps.
My one regret is that I tried using a heat gun to soften the adhesive. While her screen was cracked, the LED display was still working. After using the heat gun, the LED display was no longer working - so I had to order a new one (they’re not cheap). At the time, I did not know about the iOpener. I would be very curious to give it a try. As long as it provides enough heat, it would probably work a lot better due to the increased control in heat application. For the price, it’s probably worth giving it a shot if you’re planning on doing this.
I only replaced the back glass, it’s the only one that is cracked, tho i already have the replacement for the middle frame, I got scared that i might brake the LCD (HAHA) but this guide is spot on
This is removing both the lcd and the screen correct?
If you are referring to a touch screen, it's not. This guide is for LCD/Digitizer assembly replacement.
Jojo -
