简介
使用本指南更换三星 Galaxy A50 的后盖。
重新组装设备时,你需要更换粘合剂才能重新装上后盖。
你所需要的
在手机底部靠近USB-C端口的位置插入一个三角撬片。
将打开挡片滑动到左下角。
It would be much better to attempt the opening from the top of the phone as there is a delicate flex PCB antenna at the bottom just where you stick the pick in that can get damaged.
David Hall - 回复
Wish I would have read your comment before, since I destroyed that cable while opening my phone... It's a cable for microphone, speaker and headphone jack. Replacing it was a real pain because it's glued but luckily I was able to find a spare.
H.W -
卸下后盖。
Very straight forward and simple replacement to do with the right tools, I used my hot air gun work station so this might have been alot easier for me then someone without one? Hair dryers work too, just in case a hot airgun station is not available to you dont worry you can do this repair without, but some form of heat will make life alot simpler :)
要重新组装设备,请按照逆序进行操作。
用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。用预先切割的胶带或双面胶带固定新的后盖。
要重新组装设备,请按照逆序进行操作。
16等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
一条评论
Thank you for this write up, I wanted to insure there were no connections and overall it's just something I practice to make sure to double check rather a back cover has any hidden surprises, Trust me I've learned from experience not to Assume anything, lol. Take care, and thanks
Nur ein kleiner Tippfehler-Hinweis: (Überhitze das Gerät nicht)
Jonas Hahn - 回复
OK, korrigiert. Das kann übrigens jeder machen, iFixit ist ein Wiki.
VauWeh -
how long should the heat pack be used for?
David Hall - 回复
The heat pack is in the wrong position in photo - the glue that you are heating is actually all around the edge of the phone!
David Hall - 回复
