简介
使用本指南来更换 Galaxy A50 中已用完或耗尽的电池。如果电池膨胀,请 采取适当措施。为了安全起见,在拆卸手机前,请使电池放电至25%以下。
如果在维修过程中电池意外损坏,则可以减少发生危险热事件的风险。
重新组装设备时,你需要更换粘合剂来重新连接组件。
你所需要的
如果可能,在安装新的粘合剂并重新密封之前,请打开设备并测试维修情况。
用预先切割的胶带或双面胶带固定新电池。为了正确放置它,请将新粘合剂涂在设备中旧粘合剂所在的位置,而不要直接涂在电池上。用力将新电池按入到位。
要重新组装设备,请按照逆序进行操作。使用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。
为了获得最佳性能,请校准新安装的电池:将其充电至100%,并继续充电至少2个小时以上。然后使用您的设备,直到由于电池电量不足而将其关闭。最后,不间断充电至100%。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的社区寻求帮助。
28等其他人完成本指南。
由衷感谢以下译者:
88%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
10条评论
Great guide.. One tip… ALWAYS make sure to decharge the battery so it have no power before you do anything… example turn on wifi and stream a movie and when phone is out of power you can remove the battery.. never bend it, use heat, use fluid to desolve the glue behind battery.. never cut/damage or bend the battery and use safety glasses just in case. Battery in a mobile phone is NOT a toy
Teşekkürler. Çok açıklayıcı ve anlaşılır biçimde hazırlanan değerli bir rehber olmuş. Gerçekten başarılı.
My a50 just got a black screen, I have tried the forced reboot for a couple of time it opened but returns to black screen, now I can't open it with force reboot, is this battery or something else
allan_heyz - 回复
I have same problem in same time. On the screen, I only have a circle charging sign, but not a percentage of battery charge when it's charging normally. I think the battery's dead.
Hi Allan, It's difficult to remotely identify what's wrong with your A50. Let us know what the reason is if you can figure it out.
