简介
使用本指南来更换 Samsung Galaxy A10 上破裂或破裂的屏幕。
'“注意”':本指南指导你仅更换屏幕,而将原始框架和主板留在原处。但是,此手机的某些替换屏幕已预先安装在新的机架(也称为机架)中,这需要非常不同的过程。在开始本指南之前,请确保零件正确。
'''在拆卸手机之前,请将电池放电至25%以下”'。如果电池被意外刺穿,可能会着火和/或爆炸,但如果放电,则发生的可能性要低得多。
重新组装设备时,你需要使用“替代粘合剂”来重新连接组件。
你所需要的
卸下三颗Phillips#00螺丝(3毫米长)。
On my A10E the second screw from the right on the top line of 4 screws had to be removed also
It’s easier if you remove all 4 screws across the small top panel.
从底部卸下子板盖板。
Hola! En este punto sería muy recomendable retirar la batería, antes de calentar la pantalla, ya sea en la plancha o con una pistola de calor.
如果可能的话,在安装新的粘合剂并重新密封之前,请打开设备并测试维修情况。
要重新组装设备,请按照逆序进行操作。使用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的社区寻求帮助。
82等其他人完成本指南。
由衷感谢以下译者:
92%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
12条评论
Usefully website. Thanks ifixit team.
AK FRIENDS - 回复
screen replacement for samsung galaxy a10s…or a10 screen is the same size as a10s
Useful service guide for display replacement, best website for repairs !
The Missus dropped her phone and the inevitable happened, this guide was invaluable in helping me fit a new screen, and in under thirty minutes! Extremely grateful for this guide, definitely one of the better ones out there…
gracias por las directiones
Loved this. Thanks, Ifixit, I fixed my own phone screen. The only problem I had was not having any adhesive so my screen is still loose. It would have been helpful to have this part of the Tools needed list. I will have to buy Two-way tape at some stage. But very happy to have a screen I can see properly.
Hi Teresa, thank you for sharing your experience with us. I'm glad your A10 is up and running again! You're right, I've edited the guide and added adhesive to the necessary parts.
excelente, preciso y muy didactico
I need a replacement screen for a Galaxy A10, most I see on the web have two holes at the top but mine has only one. What is the difference and will the two hole work on my phone. Thanks
I've used your help before and found it best way, very easy to use and covered everything, I'm using it again for a friend phone and recommend to everyone to use it, thank you for your help
Nicky Beal - 回复
Thank you, Nicky!
خیلی عالی است
Habe nur das Frontglas mit Werkzeug gekauft. Kann ich nur dieses von vorn ersetzen, ohne das Gerät komplett zerlegen zu müssen? Sprich defektes Glas erhitzen und nach vorn abheben etc
Hans Weschta - 回复
Hallo Hans, leider musst du dein A10 zerlegen um den Screen zu wechseln. Hier ist der Guide für deine Reparatur: 三星 Galaxy A10 屏幕更换. Viel Erfolg beim Reparieren!
Adriana Zwink -
