这部手机有很多值得关注的地方,6处重大升级包括:
5.1英寸Super AMOLED 电容触摸屏(1440 x 2560,~577 ppi,1600M色)
搭载三星Exynos 7 Octa 7420 处理器及协 Mali-T760 GPU,以及3GB内存。
1600万后置摄像头,具有HDR,LED补光以及4K 视频录制功能。
内建支持Qi及Powermat无线充电。
32/64/128 GB存储可选(无MicroSD拓展)。
康宁大猩猩4代玻璃后盖。
我们的塑料撬片在开启过程中起了很大作用。
尽管我们的薄片在这块玻璃的边缘还是遇到了麻烦。
在老朋友iOpener大量的帮助下——全神贯注——我们终于绕边缘划了一周。
后盖终于(好吧,其实是基本上)卸下来了。在下面我们发现有一点还粘附着……但是我们无法用手直接操作。
随着中框被卸下来,我们终于可以一睹电池和主板的尊容了。
此时,我们通常会习惯性的先将拓展内存卸下来,也就是MicroSD卡。那么它在哪?哦,对了,三星公司已经把它干掉了。如果你需要额外的存储,那你最好直接买一个大容量的,因为无法扩充容量。
中框中填满了“糖果”——成吨的触点,一个NFC/无线充电线圈以及一个扬声器。
我们很乐意现在就取出电池观察一下,然而此刻我们必须先解决如何从主板上拔下它的连接。
I fix phones for a living, and today I ran across what seems to be a later revision of this phone that has BIG PROBLEMS here. The screws on either side of the charging port are missing from this one - the antenna runs straight across and the screw holes are gone. On the inside, the plastic part of the speaker includes an extra bracket that basically has the charging port sandwiched between the housing and the speaker. There's also a screw holding the headset jack to the front housing that can't be removed until the rear housing is off.
The end result is that taking this other version apart will probably result in the charging port flex destroying itself and the need to replace the back housing and speaker.
The model number on this one was SMG925VZWA, a US Verizon version. I didn't have any other ones handy to compare the model number, but you can definitely see the difference once the back glass is off. If those screw holes are missing, be VERY careful taking it apart, and expect to need more parts.
在中框上的贴片天线,如此可爱。
三星一贯的风格,天线是通过超声波焊接到中框上以保证稳定性,还能节省空间。
我们还在中框发现一个为电源键而留的孔。
Space continuum cracked me up.
Me too! I had to do a double read it made me laugh out loud!
whats the function of the golden belt lining that touches the black cover on 2 ends and goes round the camera
将所有的连接器都撬开后,主板差不多要从显示框架上自由了——和我们首次在盖乐世S5上见到的一样,不可靠的反向IO板连接。
我们从主板上拔下了后置摄像头一看究竟,这块板子上的芯片:
华邦电子(Winbond) W25Q32FW 系列闪存
应美盛(InvenSense) IDG-2030 用于光学稳定的双轴陀螺仪
1600万像素的OIS后置摄像头和500万自拍摄像头。
ChipWorks在他们的最近的盖乐世 S6 分析中指出,看起来在三星的旗舰手机中越来越多的芯片源于in-house模式。在主板的前侧,可以看到:
三星 Exynos 7420 Octa-core 处理器 - 64位, 2.1 GHz 四核 + 1.5 GHz 四核, 及三星 K3RG3G30MM-DGCH 3 GB LPDDR4 RAM
三星 KLUBG4G1BD 32GB NAND 闪存
思佳讯(Skyworks) 78041 混合多模多频 (MMMB) 前端模块 (FEM)
安华高(Avago) AFEM-9020 PAM
欧胜微电子(Wolfson Microelectronics )WM1840 音频解码及美信(Maxim) MAX98505 DG级音频放大器
三星 N5DDPS3 - 类似在盖乐世S6上发现的N5DDPS2 , 可能是NFC控制器
应美盛(InvenSense) MP65M 6轴加速 + 陀螺仪,及三星 C2N89U (可能是图形处理器)
Does the phone support MHL? I did not see the chip for MHL like S5
玻璃背板和粘得很牢固的电池?三星你是不是偷师了苹果?
不管怎样苹果已经放弃了这么干。没有方便的易拉胶意味着你每次打开都要重新贴一次这讨人厌的胶条。
HAHAHAHAHAHA now THAT was hilarious :D
bigtity007 - 回复
I loved the jokes. Thanks guys for making this article so fun
这看起来又是退了一大步,S6 Edge放弃了S5上和闪电一样快的Micro-B USB 3.0接口而转向了普通的microUSB(2.0)接口。
欢迎来到2000年。
With the very least frame modding and loss of headphone jack. If you use the s5 modular cable. If it will even plug in or work.
我们让Edge躺在 iOpener下面,希望它起来的时候神清气爽顺便释放些胶水。
让我们举起玻璃杯。。。等等,这是正常的吗?
看起来撬进这弯曲的显示屏意味着我们只是把它分开了一点点。哎呀呀。
Did you just break the screen? Does it still work? If it doesn't is there any way to replace the home button without breaking the display?
My screen is cracked and I really don't want to pay 200 dollars for it to be fixed. Is it really impossible to replace just the glass without breaking the digitizer?
repair-ability is a 3 when the apple watch got a 5 where the majority of the apple watch is "unrepairable". Something needs to be done with yalls scale as currently it looks like your an apple supporter and Samsung basher. Having to mod your tool with a file just to remove the screws on the apple watch trumps a glued back or glued battery in my opinion of repair-ability. Not trying to create any waves just pointing out the lack on continuity across your repair-ability ratings. Thanks for giving me a heads up look at the teardown for these devices as it's much appreciated.
Look at what you have to do to replace the screen on both devices. the edge needs to have complete disassembly the watch just pops off. the battery on the edge requires removing the back glass and a complete teardown, the watch just remove the screen and there sits the battery
wesley burson, the phone doesn't need a full disassembly. At stage 8 you can remove the LCD.
Point taken for screen and battery replacements... what about everything else tho? On the apple watch jut about everything else was "unrepairable". How is a device with multiple components "unrepairable" ranked higher then a device that is reparable regardless of the difficulty. I would think "unrepairable" would have a lower score for the simple fact that if one of those components have an issue there is no repair option where with the S6 at least it's possible to repair. We are talking repairability here on an over all scale not just screens and batteries.
I believe there should be subcategories like:
1. Openability
2. Repraceability
3. Destructibility
4. Separability/Removability
Then the average will give the Repairability score. :)
dyanro -
Is the glass able to separate from lcd?
there is a missing part you didn't mentioned on top of the phone named "Ear Speaker & RCV Sensor - GH96-08091A" which controls proximty, front led and also speaker voice. why? http://i.hizliresim.com/BPLWZQ.jpg http://i.hizliresim.com/Zk9jLo.jpg
它是弯的!拨开显示屏让我们看清了三星的屏幕是如何在手机的两侧弯曲的。
装在显示器背面的是惯用的触摸屏控制器,这次是STMicro FT6BH。
Hi
When removing the glass did you break the digitizer... from what I know the digitizer is glued to the screen glass but yet is connected to the lcd.. so when you remove the glass from the lcd you inadvertently break the digitizer in the process.. did you have any issues with this...
Many thanks
Steven Steward
Hi...I actually have a problem with the reciver of the phone and also the aux isn't working..which part should I buy to get it fixed..
Jayesh -
My phones voice reciver and the aux ain't working which paet do I need to buy to fix it...
Jayesh -
S6 egde voice reciver and the aux isnt working which part do I need to replace for it...model no g925t
Charge port handled all of those features
Wow! 50% yield. That's terrible. Very interesting reading iFixit! Thank you.
That's insane. That just gave me a reason to not buy a galaxy. They need to figure out a better way of manufacturing the screens. Which also explains why Samsung parts are so expensive compared to Apple. The yield. You are actually layig Samsung for 2 screens that's ridiculous.
Samsung Galaxy S6 Edge的可修复得分:3/10(10为最易修复)
许多组件是模块化的,可以独立更换。
改进了S5的设计之后,您不再需要拆下显示器就可以进入手机并更换主板。
正面和背面的玻璃使得易碎性加倍,背面玻璃上的强力胶水导致难以进入设备。
电池紧紧贴在显示器背面,并埋在中框和主板下面。
在不破坏显示器的情况下更换玻璃是十分困难的。
Buongiorno,
complimenti per una guida così chiara.
Il punto è che avendola seguita, ho cambiato la scheda madre del mio S6 Egde (925F).
Funziona tutto egregiamente ma la ricezione e soprattutto l’invio dati sotto copertura 3G, 4G, LTE è lentissima.
Lo Speedtest spesso dice che la velocità di upload è zero. Ho anche fatto un factory reset, ma niente…
Cosa posso aver sbagliato? Cosa devo controllare?
Grazie mille in anticipo per la risposta
由衷感谢以下译者:
95%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
24条评论
Holy He11 you guys got the phone that says "A S S" in it. I wouldn't rate this a "3" this is more like a 5 in my book. You guys rate a m7 as a "1" which is one of the more difficult phones out there but its still easier than some of the older Motorolas.
Do I know you??????
That sure looks like a MicroSD receptacle on image "Step 11" on the bottom left corner of the board. Is that the Simm Card receptacle or a MicroSD receptacle?
That's the SIM card receptacle.
Ryan -
SD Card Yeah Nelson Bush, that is an SD card slot. Everybody in Samsung forgot they put it there. Ooops.
Hi,
I've just replaced a broken screen, everything went well, but soft keys (Back and Recent apps) not working on new screen ! Are those keys being controlled by screens digitizer of the daughter board that has the LEDs for them ?! should I send back the new screen as faulty ?! or sth happened to daughter board when I opened it (which I doubt).
Any suggestion ?!
Thanks
Voidminded - 回复
The soft keys are part
Of the screen on the s6 edge. The standard s6
Soft keys are on the charge port. So faulty screen
Incorrect. The touch buttons on the S6 Edge are also on the daughterboard, but are not ribbons that attach to the screen frame (as with the S6). Instead, they are on the opposite side of the daughterboard and are pressed into place by the natural pressure of the board against the screen. This makes the replacement of a charging port much easier due to not having to remove the LCD from the frame, which is tedious. Replacing the home button is the same as on the S6 - you will have to remove the screen frame from the LCD to access it.
mbrulla -
UPSM ON
UPSM OFF
Work?
would the main motherboard from a G925T work with the parts from a G925i
i dropped my phone in water. is there any way to recover the data or fix the phone?
How To Remove The Wi-Fi Adapter? (For Kid-Safe Phone)
It's much easier to root the phone and disable the wifi chip in the build.prop file. Google that.
I would be more worried about disabling cellular than disabling wifi.
Hello! Where can one get a genuine battery replacement. Samsung in my country won't replace my faulty battery saying I didn't buy the phone from the region.
AbdulAzeez - 回复
I have my s6edge+ all in pc's I need digitizer LCD battery. And the main belt wire front face glass weird mine was plexiglass and I'm ready to assemble.
Hello Guys i have probleme in my phone samsung galaxy s6 edge the probleme is many stop in work and many time i restard my phone his stopped in samsung logo of depart please help me when probleme hardware or software thanks.
Hi, I replaced the sim card reader (not the tray) and now the phone does not turn on wifi. It attempts to turn on wifi for about 10 minutes and gives up. Would appreciate if you can suggest any solutions. Thanks
Why have a fake picture of the phone for this??
iliketurtuls - 回复
Yeah omg i just noticed it!
allafman5 -
Good question.
HakanEr -
Wait, what? Which picture?
Lucas Gallindo -
I am so sick of being told no by manufacturers when it comes to repairs. The argument about needing to design a device this way to make it thin is a big fat lie.
gallardo - 回复
Isn't the reversion to usb 2.0 for the rapid charging to work?
codycowgill - 回复
