简介
视频概述
输入:*#06# 可以显示IMEI
输入:*#1234# 可以查看Android(Copyright Google)版本
输入:*#12580*369# 可以查看主版本
输入:*#0228# 可以检测电池状态
输入:*#0808# 可以检测USB设置
输入:*#0011# 可以查看服务版本(运营商)
输入:*#0*# 可以服务/测试隐藏功能
输入:*#9900# 可以打开系统转储菜单
要还原设备,按照相反的顺序进行操作。
要还原设备,按照相反的顺序进行操作。
93等其他人完成本指南。
由衷感谢以下译者:
100%
zhanbohan2008@qq.com正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
16条评论
Does this work with all Galaxy Note 3 phones? I have one from US Cellular and can't seem to get this to work.
Enter this code first *#22745927 to enable / disable hidden menu.
ZFix -
Yes, unless your mobile phone is installed with a system that is not a Samsung Experience.
You're running a custom ROM. Codes can very between ROMs in certain circumstances. Have you tested these on the stock ROM?
I can not make phone calls with my note 3 after I purchased a activation kit for net10. Im not sure of why is it my apn settings or where do I go from here? I have tried every thing
could u help me i have samsun glaxy note 3 . when i want to dile number it outomaitcally add +1 then i cant call
i cant calll.
how to remove +1 from my all contact .
allso, when i want to from google direct take number then otomatically it added +1
how to remove +1 for contact . i have lots number . when i call , all added +1
pleas help me
please help me my phone is invert colour mode how can change normal mode?
I don't know. You can ask Samsung customer service.
Go to setting type on searche
Inverted and deactivate it .
It's Samsung Galaxy note3 and only the touch screen doesn't respond for no reason. I dialed *#0*# nd clicked for touch ….but it didn't work (no hardware damage).Help.
Dear I have N900V samsung Note 3, no any code works on it even *#06#
Pls help
I have an /sm_n9005
With a custom room lineàge os àndro pie 9 the self test doesnt come out when i dial *#0*# help
I can not make phone calls with my Galaxy j7 after I insert sim card for few calls one or three calls after that “ not registred on network “ command appears on the screen . but the sim card works properly on other phone,I have tried every thing. please help me to fix this problem
eshetu_bkl - 回复
I cannot activate MTN bundles with my Samsung Galaxy Note 3 I can check just credit but to process any other code it cannot
Sir my phone mic works on calls with open speaker and not record voice on whattsapp
not working in my verizon Note 3
HIREN PATEL - 回复
Same. - also Verizon unit. (w/unlocked BL) none worked.. - Absolutely LOVE V/branded phones. :D
Thor - 回复
Ussd code not displaying,in my Samsung Galaxy note 3 olleh.every time when I display it says try again.help me please.
lameck emmanuely - 回复
If Samsung Note 3 Wi-fi is not turn on how to fix it?
Shahg - 回复
