简介
使用该指南移除 SIM 卡。
你所需要的
把手指或塑料开启工具插入电池底部右侧的凹槽中向上掀。
把电池从手机中移出
The battery will need to be charged after it is placed in the phone. No one told me that and I bought a battery and thought it was bad. Keep the phone off and insert the charger. You will need to charge it for several hours before you can use the phone.
使用指尖,把microSD卡直接向下拉出卡槽。
将microSD卡从手机移除。
I found removing the SIM/SD card with my fingertip a little difficult – not enough friction. So I used a 'rubber' (in US English it's called a pencil eraser or just simply, an eraser.
Simple, cheap (zero) and effective! :)
Cheers.
John
johnsg0053 - 回复
重复以上步骤移除 SIM 卡。
Actually this isn’t as easy as it appears in the photo and instructions, since the SIM card does not have a notch that you can use to pull it out. In my experience I’ve found that the best way to remove the SIM card is by pressing down somewhat hard on the SIM card, and then push-pulling it outward.
请按逆序操作重新组装你的设备。
请按逆序操作重新组装你的设备。
34等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface.
Chris Ward - 回复
"Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface"
Good suggestion. Alternatively..........use a pencil eraser!
johnsg0053 - 回复
Why is my galaxy s5s screen black..I can get the buttons to light up but the screen won't come on..
