简介
去年的Galaxy Note7
煽动了我们对于智能手机不满情绪的火焰。 也真的燃起了火焰。 现在火焰回来了,转世为"盖乐世 Fan Edition"让我们把它拆解开吧!希望这次不要再有火焰了。 有关更详细的分析请参阅我们下面的链接Note Fan Edition blog post.
时刻关注我们最新的维修新闻:关注我们的推特,脸书和Instagram。
你所需要的
视频概述
请阻止我们,如果您先前听到过这些数据
曲面5.7" Super AMOLED 显示屏 分辨率为2560×1440(518 ppi) 以及 大猩猩5代玻璃。
Exynos 8890 Octa Core处理器,具有4 GB RAM + Mali-T880 MP12 GPU
1200万像素,ƒ/ 1.7的后置摄像头,具有OIS,双像素自动对焦,4K视频; 500万像素/ 1080p自拍前置相机
64 GB内部存储,另外可通过MicroSD扩展最大到256 GB
虹膜识别,指纹识别
S Pen,USB-C 和耳机插孔
IP68防护等级
历经千辛万苦后终于将最新Note让人厌烦的玻璃面板卸下来了(和上次一样糟糕),我们看到了翻新的硬件。
第一眼看上去,没有什么变化。 第二眼,嗯在天线形状上有些细微的变化。
将天线组件剥离后,我们终于可以看到电池了。
手机有了全新的电池。 这一块6月20日生产,所以是真的新款手机。
12.32Wh与上一代13.48Wh相比,电池容量的确小了些
但这块电池容量还是比iPhone 7 Plus拆解 (11.1Wh)要大,缩减9%的容量来使得Note 更加安全。
Can we buy the battery itself? I have my Note 7 and I would like to switch the battery.
有一些传言说,这个翻新的手机将配备一个较新的骁龙 821处理器来替换Note7中的三星Exynos Octa 核心。 所以我们卸下了CPU上的保护壳,仔细看看:
三星K3RG2G20CM-CGCJ 4GB LPDDR4 RAM分层在Exynos 8890 Octa Core CPU
Samsung KLUCG4J1CB-B0B1 64GB UFS 2.0
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
23条评论
Everyone keeps calling it the 'fan' edition, but I can't see a fan anywhere. You'd think there would be space next to the smaller battery, and the fan could also help stop it exploding.
- Bob from Hartlepool.
Doubt it'd be worth the effort, since the OG Note 7 they showed was a VZW model, which got software updates to disable charging, along with most of the other Note 7's out there.
JJ Davis -
JJ Davis Reply is totally lame. It wasn’t hard to dodge the Poison Pill Update that prevented the Note 7 from charging. I did. And my N7 is still my daily driver in Dec 2019 … however, it is time for a new battery … and my hope is the Note FE battery is the replacement … which I am trying to discover.
Preston -
On my of note 7 now which is supposedly imei blocked in Australia but my stock note 7 is magic & gets cellular data again after being wifi only for a while there. Still 100% charge & blocked all updates. Never a sign of heating. I think the early ones from 1st recall of exynos versions were safe b4 the got flooded trying to replace all the usa 820 versions too. Mine has never been over 38degrees when my note5 died from overheating. I use fast wireless&wired & never an issue with heat. I even slept on it once so no sharp welding bits in my battery. I get led covers too. I wanna find a cheap s view cover. I've got a spare black one too i may root as i got an s7e for its imei.that 1 is blocked. Hopefully I can clone this 1 over with all its app data to keep the disabler apps working but i can root or keep for spares.might order a new back glass just in case. Note7 is still the greatest. Last sammy with real buttons.
Is the cost to swap out the battery on the Note 7 just waaay too much to make it worth sending back out on the American market with a proven safe battery? It seems like a no brainer to refurbish this phone and sell to the public to recoup some of the loss that Samsung had to take. Does anyone know how the reception in Korea was? People waiting in lines/camping out to get one of the F.E.'s?
I need to buy that motherboard . How much?Mine shipped and received DOA. Any idea where to order one? I have note 7 for parts but different board.
The FE is made from untouched note7s and note 7 parts, so it is not a refurbished phone.
Oh btw I have the note FE as my main phone. It ceratinly is a great phone.
thanks to work
The blue color is best for me as well as i am a fan of Samsung and blue is my favorite color. Amoled Display and all in detail.
Nuzaf Naim - 回复
I want a screen to my fan edition
Need battery replacement for my note fe. Anyone?
Is it possible and or safe to place a Note 7 battery in a Note FE?
No it’s not safe. Please don’t do that.
Jeff Suovanen — Thank you for your ‘chicken little’ comment. Your concern was appreciated EVEN IF misguided. It is totally safe to mess with the N7’s battery IF you have the skills to correctly disassemble the N7.
Miguel Eduardo — The S7 battery works as a replacement (if you know how to remove the N7 battery’s connector parts and solder them onto the S7 battery. The S8+ and Note 8 batteries may work. But I am trying to find a Note FE battery to try … but can’t locate one.
Here are sources to help accomplish your objective:
https://forum.xda-developers.com/note-7/...
https://www.ibtimes.com/samsung-galaxy-s...
It is very possible to replace the Note 7 battery with another Samsung battery… if you have the skills to modify the non-N7 battery. But I am hoping the Note FE battery presents the easiest solution. Just can’t find one to work with.
Preston -
Has anybody found and installed a Note FE battery in a Note 7? If so, did the FE battery fit into the N7 battery compartment without any issues? And where did you find an FE battery?
BTW, for naysayers, I have used my N7 daily since September 2016. When the Note 8 came out, I bought one and hated it. I gave the N8 to my wife and kept using my N7. The N7 and Note 4 were the two greatest Android phones produced so far. Both of mine are still in service. If you never used either, you would not understand.
Anyone willing to sell, I need to fix the screen and back glass of mine.
There is one important difference. A change in the placing or removal of the chip that talks to the led & s view covers meaning they will not work with original note7 accessories. But you get a free clearview case now. I'll stick with my original & enjoy my extra 300mah & led covers.
David Berry - 回复
