简介
本指南将介绍如何从显示屏部件中移走所有内容。
你所需要的
沿后壳边缘滑动塑料开口工具。
轻轻地从手机上提起后壳。
取下耳机插孔旁边的单个螺丝。
You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
使用镊子拉出母版。
My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
soha Javed - 回复
My wifi hotspot is not working
提起撬棒将插座组件与主板分离。
拉动以取下。
卸下位于左上角的金属支架。
用镊子小心地拉起振动马达。
使用镊子从前部组件提起USB端口。
您现在就剩下了显示组件。
Wonderful description.
按照本指南相反步骤来重新组装设备。
按照本指南相反步骤来重新组装设备。
146等其他人完成本指南。
由衷感谢以下译者:
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
10条评论
This tutorial is incomplete, for instance the 'vibrator motor' removal does not specifies that this also removes the power button, and the removal of the front camera and light sensor is omitted, and the fact that heating the usb port part is very helpful if not mandatory before lifting it. I followed the video tutorial here which is complete: Samsung Galaxy Note 3 Display Assembly Video Tutorial Replacement
warning :
on the new part (display assembly) don’t forget to remove plastic protection on the radiator of cpu !!
I have successfully replaced the display with a new display, at which point the power button wasn’t working properly because I didn’t install it properly - fixed that, and I have now noticed that the phone will charge with the back plate on, only, however if I screw the back plate in this stops it from charging. What am I doing wrong?
