跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
一加6T后盖更换
你所需要的
  1. 一加6T后盖更换, 后盖: 步骤 1 中的图像 1,1
    • 确保手机已关闭电源,并且后盖朝上放在稳定的表面上。
  2. 一加6T后盖更换: 步骤 2 中的图像 1,1
    • 将SIM卡拆卸工具插入手机左上角的小孔,以弹出SIM卡托盘。
    • 小心地从托盘中取出SIM卡。
    Remove the SIM card tray from the phone. Don't need to remove the actual card from the tray, just be careful you don't lose it…
    SayIDidIt™ - 回复
  3. 一加6T后盖更换: 步骤 3 中的图像 1,1
    • 使用吹风机或iOpener松开手机内的粘合胶。
    • 如果选择使用吹风机,请将吹风机放在距离手机至少8英寸的地方,并在手机边缘以圆周运动加热2分钟。
  4. 一加6T后盖更换: 步骤 4 中的图像 1,3 一加6T后盖更换: 步骤 4 中的图像 2,3 一加6T后盖更换: 步骤 4 中的图像 3,3
    • 将撬片插入手机加热过的一角,以将其轻轻抬起。
    • 将塑料卡插入后盖上略微抬起的部分,然后将卡轻轻滑到抬起的电话外壳下方。
    • 会有少量的阻力,但这是正常现象,因为卡正在去除手机内的粘合剂。
    • 从手机上卸下后盖。
    Do you need to replace the glue when reassembling?
    S Marlin - 回复
    It was sufficient for me to re-heat the adhesive from the phone.
    Also, I used a pair of tweezers to lift the initial corner, which was a breeze compared to the Jimmy’s as suggested by the guide.
    Michel Rummens - 回复
    The gaps were very tight. After warming the adhesive, it was helpful to have a helper use a suction cup to tug on the back to enlarge the gap for the jimmy.
    tbrannam - 回复
    Theres a big patch of glue on the right side of the camera. Be careful with this part, cuz ure proabably under the curved side trying to get inbetween and in my case this shattered the coating of the backside of my phone. It still works, but it has a spider skin on the back now.
    Shwyne - 回复
结论
要重新组装设备,请按照逆序进行操作。
17等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
3条评论
I wonder if this is the same for OnePlus 6 (6000/6003)?
karlkristians - 回复
another greath guide, repaird check.
In same time rplacd the battery so phone is ready for another few years
yoeri - 回复
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
Alexandre Herbreteau - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 51
过去 30 天: 175
总计 18,305
