跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的OnePlus 5,请使用我们的维修手册
    最后的想法
    • 没有定制化的螺丝钉。
    • 一加5的显示屏是由分开和可从复使用的塑料夹子固定的。
    • 大多数部件例如相机,type-c口,耳机插孔等用排线链接是模块化的,易于分离。
    • 电池有一个拉环易于拆解,但是要移除主板才可以。
    • 显示层和玻璃保护层被集成在了一起,home按键被集成在了显示模块中,这使得修复变得昂贵且复杂。
    可修复性评分
    7
    可修复性10分中得7分
    (10是最容易修复)
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
16条评论
Wow!! it is good, thank you.
Kaye - 回复
Wonderful video as usual. If one were to take theirs apart would it be as 'tight' once it was back together?
I think the buttons edges are a little sharp and I'm tempted to take it apart to put a little bevel on them.
I'd like it if the screen didn't end up being loose or have gaps around the back cover.
David - 回复
Is there an audio DAC founded? Can you tell us wich is it?
David Sepúlveda - 回复
The Snapdragon 835 has a built in DAC+amp with up to 4W output. https://www.qualcomm.com/products/snapdr...
George A. -
for those who dont have yootube and chance of a standard layout detaillng this teardown...?
P Stephenson - 回复
Link for screen please? My screen is broken and I need one but can't find the screen for OnePlus 5 in iFixit store!
Cheikh Alyounis - 回复
I appreciate the video, but I like ifixit for the manual-like write-ups. If I am ever unfortunate enough to have to tear mine down, I will make one.
Zack Westlie - 回复
Is there a +5V point on the board that is equivalent to the +5V from the charging port? Asking to decide whether or not we can solder a qi wireless coil in.
Azrudi Mustapha - 回复
my power button broken. the phone kept on off and on by itself
Azriff Reza - 回复
mine the power button gave way.. the phone kept on on and off by itself
Azriff Reza - 回复
I have a problem with my wifi conections form Oneplus 5 …where is the wifi positioned in the phone? please help..
DouaPuncte G - 回复
Is the 5T equally easy to repair? Or harder?
Suchiththa Wickremesooriya - 回复
Is there a major difference between the 5 and the 5T?
Is the OnePlus 5T much different from the OnePlus 5?
THX1138 - 回复
This video really sucks. It’s cut way to fast, you just don’t see anywhere how disassembly is done. Instead the talk is just advertising the phone.
JPT - 回复
The ‘Final Thoughts’ above has this:
The display and glass are fused and the home button is integrated into the display assembly making repair of all three of these parts more complicated and expensive.
I’ve just changed my home button/fingerprint sensor (thanks ifixit!) and it just presses out with just a bit of careful pressure on each side. It’s not integrated.
BTW, none of the repair guides mentioned that you need to put double sided tape or other suitable adhesive on the back of the replacement button before pressing it into place.
David Hoffman - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 56
总计 65,936
