跳转到主内容
Sony Handycam HDR­-CX220 Buttons Replacement
你所需要的
  1. Sony Handycam HDR­-CX220 Buttons  Replacement, Battery: 步骤 1 中的图像 1,1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Buttons  Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: 步骤 3 中的图像 1,3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: 步骤 3 中的图像 2,3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: 步骤 3 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Buttons  Replacement: 步骤 4 中的图像 1,3 Sony Handycam HDR­-CX220 Buttons  Replacement: 步骤 4 中的图像 2,3 Sony Handycam HDR­-CX220 Buttons  Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Buttons  Replacement: 步骤 5 中的图像 1,1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: 步骤 6 中的图像 1,3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: 步骤 6 中的图像 2,3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: 步骤 6 中的图像 3,3
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  7. Sony Handycam HDR­-CX220 Buttons  Replacement: 步骤 7 中的图像 1,2 Sony Handycam HDR­-CX220 Buttons  Replacement: 步骤 7 中的图像 2,2
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
结论
2等其他人完成本指南。
Keven
于03/11/16注册
811 声望
创作了6篇指南
团队
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G5
3 名成员
创作了12篇指南
一条评论
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 891
