简介
您可以将设备重置为原始出厂设置,并删除所有的个人数据。这些操作在您的设备偶尔不正常工作时必不可少。
你所需要的
复位
您可以在停止响应或无法正常重启的情况下强制关闭设备。设置与个人数据不会被删除。
内存卡卡盖子
USB数据线接口盖子
SIM卡盖子
打开 SIM卡盖,你会看到一个小红色的按钮。 按它,振动三下后,设备将关闭。
恢复出厂设置/硬复位
转到设置>备份和重置
您可以选择备份数据(您必须拥有Google帐户)。
恢复出厂设置后手机会重启。
在此插入翻译
您成功完成了吗?
I'm dumb and put my phone in water help
I am so stupid
I am dumb and put my phone in water help
I am so. Dumb
要重新组装你的设备,参照这份指南倒序操作。
69等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
29条评论
I will alrrady presss red bottan then he 3time vibration after no responses. Why I want to broken my pattern lock ...pls help
the same as yours
forget my paaword
i cant get into my menu
اصول صحیح مطالعه
Normally if you press for 5 sec the ON/OFF button and Volume + button , It will Soft reset
it worked :) thaks!
heraa -
It worked for Z1 Compact, thanks
Hi, I did as per your quote. My mobile screen got froze and did the ON/OFF button and Volume + . And when I switch it ON normally, it doesn’t turn ON. It just flashes Red LED light 3times. I have changed and inserted with NEW battery, but still it doesn’t turn ON.
Also I won’t loose any of my data, when I did the SOFT RESET.
ram -
Hey I have z1 when I touch settings operate speaking also how can I fix it ?
fanu malik - 回复
I've done all this several times but still no luck my son's phone has a number pin and we have no code for it and it's not doing a factory reset how can I fix it
Try what i suggested below :) Hope that helps
If you have signed into your google account on your phone, you should be able to sign into Android Device Manager: https://www.google.com/android/deviceman..., here you will be able to do a password removal and/or a factory reset in which everything on the phone is deleted.
Hope everything works now :)
Why is that, everytime i press ' erase everything' the 'Confirmation of PIN' will pop-up, but i dont have pin that register. Help! What to do?!
Also, the problem of my xperia z1 is that, when i open it it just stay good for 15secs. Then it says ' (etc. Not responding) then it gives 2 options, one is WAIT and the other is OK, then if i press ok and wait. The screen will turn black. Then it will restart automatically again and again.
refulgentel: I got exactly the same problem since yesterday, I tried to do the hard reset( with 3 different methods) but that's didnt worked
Fouond any solution ? Same here
kacmar -
Hi, I want to do the factory data reset my phone sony experia z1.
After click erase everything button, it request to confirm password?
but it pop up try again.
which password should i use?
the above procedures doesnt work at all. had to use Sony PC Companion software and select Repair Device to reset/erase the phone.
Not it will not work, because it will appear type pascode.
my sony z1 automatic shut down,software change,battery change,other than the board the whole changed same problem.
but main camera removing mobile ready
camera fixing,or camera changing same problm
eany solution?
Perfect Sr - 回复
When i put my card sim in he begin dowing stufs . Can i fix it pls help me.
i cant on my phone. Its keep on and off.. How to do hard reset
Try already but the red small button is not functioning..and totally not open..but if I charge is OK..
Roda Ledesma Dumayag - 回复
I try already to preS's that red small button but no responce..totally shutdown if I charge mobile is OK..but not open..tnx
