跳转到主内容
更换iPhone 8的五角螺丝
你所需要的
  1. 更换iPhone 8的五角螺丝, 卸下五角螺丝: 步骤 1 中的图像 1,1
    • 在你开始之前,请将你的iPhone电池放电至25%以下。 充满电的锂离子电池如果被意外刺破,可能会发生着火和(或)爆炸。
    • 在开始拆卸之前关闭您的iPhone。
    • 卸下iPhone底部的两个3.5毫米五角螺丝。
    • 打开 iPhone 的显示屏会损害其防水密封。在继续执行此步骤之前,请准备好更换密封件,或者如果您在不更换密封件的情况下重新组装 iPhone,请注意避免接触液体。
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - 回复
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - 回复
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - 回复
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - 回复
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - 回复
结论
要重新组装您的设备,请按照逆序执行这些操作。
14等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Adam O'Camb
于04/11/15注册
196,194 声望
创作了416篇指南
2条评论
Why. Just why.
The Stuff - 回复
This guide is used by many other guides as first step! Don´t laugh about it.
VauWeh - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 58
过去 30 天: 175
总计 13,598
