跳转到主内容
更换iPhone 6 SIM 卡
你所需要的
  1. 更换iPhone 6 SIM 卡, SIM 卡: 步骤 1 中的图像 1,2 更换iPhone 6 SIM 卡, SIM 卡: 步骤 1 中的图像 2,2
    • 用SIM取卡针或曲别针插入SIM槽旁边的小孔。
    • 按压弹出卡槽。
    • 这可能需要稍微大的力。
    Why isn’t this the first step in the process? Seems unnecessarily risky to fumble with popping the SIM in and out when you’ve already opened up the phone.
    Perrin Haley - 回复
    If you don’t have something small enough to open it, you can use the lever when the screen is off.
    Lucas Rowlands -
    I actually removed the simcard as the first step because I didn’t want to risk fumbling with an open phone (as someone previously mentioned)
    twcheng93 - 回复
  2. 更换iPhone 6 SIM 卡: 步骤 2 中的图像 1,1
    • 从iPhone取出SIM卡槽。
    • 当重新插入SIM卡,请确保它是相对于托盘的位置。
    After reassembly phone would not detect SIM Card.
    During repair while components were out of phone I used that opportunity to straighten the back case that was bent. While straightening the back case I bent the thin edge of the back case by the SIM Card slot. SIM Card would click into place and seemed to make a good connection but the phone would not detect the SIM Card. After really straightening the back case by the SIM Card slot almost back to cherry the phone would now detect the SIM Card. The tray has to fit really flush with the case.
    johncrowley111 - 回复
    My flashlight has stopped working altogether. It was intermittent for a while. I believe them to be original. When I try to use the flash on my camera app, it flashes weakly but not enough do really help. Any chance the flex went bad or is there a logic board issue? My other two iphones with the same apps and the same updates are not having any problems.
    Jason Stein - 回复
    Bonjour j'ai un iphone 6 problème réseau
    karim kaladi - 回复
结论
请按逆序重新组装你的iPhone。
71等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7条评论
Shouldn't the difficulty level on this one be "easy" rather than "moderate"? After all, you can do this with a paperclip.
Eric - 回复
Vous avez supprimé mon message mais je reviens le mettre à nouveau. C'est vraiment un astuce difficile à deviner . Vous ne cherchez qu'à remplir votre blog , c'est trivial remplacer sa carte sim
Annonce France -
Need to buy a new sim card holder
Richard LaVigne - 回复
Where can I buy a sim card complete holder
what does “,puk”, mean for a locked sim
Barbara Ann Dorn - 回复
can my iphone puk number be restored without going to the phone store ? how many numbers are in a ( puk)? why did my sim lock up on me ?
I know is kinda offtopic, but if anyone want to unlock iPhone free you can check Unlocky Tool :)
Vali Dragomir - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 146
总计 51,859
