跳转到主内容
更换Shark Navigator的滚轮刷盒
你所需要的
  1. 更换Shark Navigator的滚轮刷盒, 滚轮刷盒: 步骤 1 中的图像 1,1
    • 撬出两颗装在滚轮盒下面正前向位置的小轮子。
  2. 更换Shark Navigator的滚轮刷盒: 步骤 2 中的图像 1,2 更换Shark Navigator的滚轮刷盒: 步骤 2 中的图像 2,2
    • 拧掉滚轮盒底部的10颗飞利浦螺丝。(有两颗在上一步骤移出的小轮子下面)
    • 提示:这些螺丝有不同的长度,最好标示 好各螺丝的位置方便于重新装配。
  3. 更换Shark Navigator的滚轮刷盒: 步骤 3 中的图像 1,1
    • 拆掉白色的塑料壳,让滚轮盒朝下。
  4. 更换Shark Navigator的滚轮刷盒, 滚轮刷盒: 步骤 4 中的图像 1,1
    • 将滚轮刷盒从固定器上提起。
结论
若想重新组装设备,请倒序按照本指南操作。
42等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Kevin Fu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jeremiah Shyne
于03/27/15注册
1,403 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 的会员
UMASSD-KISH-S15S5G4
4 名成员
创作了16篇指南
35条评论
Instructions where so easy to follow & right on the money. It took me 11 min from start to finish. PERFECT!!!
Cole bohn - 回复
Very helpful and easy. Thank you.
Kristi cox - 回复
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
birdofpyre - 回复
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
falynkinsey - 回复
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
interhome1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 61
过去 30 天: 213
总计 98,984
