跳转到主内容
更换Shark Navigator的滚轮刷盒
你所需要的
  1. 更换Shark Navigator的滚轮刷盒, 滚轮刷盒: 步骤 1 中的图像 1,1
    • 撬出两颗装在滚轮盒下面正前向位置的小轮子。
  2. 更换Shark Navigator的滚轮刷盒: 步骤 2 中的图像 1,2 更换Shark Navigator的滚轮刷盒: 步骤 2 中的图像 2,2
    • 拧掉滚轮盒底部的10颗飞利浦螺丝。(有两颗在上一步骤移出的小轮子下面)
    • 提示:这些螺丝有不同的长度,最好标示 好各螺丝的位置方便于重新装配。
  3. 更换Shark Navigator的滚轮刷盒: 步骤 3 中的图像 1,1
    • 拆掉白色的塑料壳,让滚轮盒朝下。
结论
遵照相反的组装顺序来重新组装你的设备
19等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Jeremiah Shyne
于03/27/15注册
1,403 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 的会员
UMASSD-KISH-S15S5G4
4 名成员
创作了16篇指南
16条评论
Tried driver tips on two MULTI-TIP tools (standard & metric), but none fit. Looks like a very small 6-sided star w/a hole n middle. Trying again tomorrow w/mini metric set. I agree, 10 screws, two under wheels is way too much trouble for something you need quick access to often for brush cleaning. The hose has several places where it comes apart very easily. I was impressed, but this roller plate ruined it.
Bettie Howard - 回复
Nice guide very easy to follow took awhile to complete only because vacuum parts I took off with very dirty had to clean other than that the guide was very very useful and very very easy to follow appreciate it!!!
Kenneth Johnson - 回复
Easy to get off but hard to get it bqck on. I put the name of my shark and took it apart and it was for a lift away which I dont have now I can’t get it back together HELP
Gail Jezik - 回复
Where did you find the replacement brush bar? Im having a heard time locating one.
meghmrr - 回复
This truly is not intended for the user to replace the roller, but rather, they would like you to pay a lot more to take it in to service! To have a star screw with hole - which is what mine has - not Philips - and under wheels and 10 of them of varying length, and good luck, like Bettie Howard said, getting the driver to fit into the deeper holes! I have no adapter or extension - means you’d have to purchase a special tool. Luckily for me, I didn’t have to replace the roller, but rather sucked a USB cable which quickly wrapped around it. I was trying to salvage it, but after 2.5 screws later, decided it was better to cut the cable!
a_1_jensen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 57
总计 86,176
