简介
按照本指南更换 Sony Playstation 4 上的硬盘。如果你要升级硬盘并希望保留保存的游戏数据和设置,请务必先将数据备份到单独的外部存储设备开始这个程序'''。
在开始任何维修之前拔掉你的 PS4。
你所需要的
要重新组装你的设备,请按逆序执行上述步骤。
更换硬盘后,你需要重新安装 PS4 操作系统。按照索尼的说明 初始化你的 PS4 并重新安装系统软件。
将你的电子垃圾送到 R2 或 e-Stewards 认证的回收商。
维修没有按计划进行?查看我们的 论坛 以获取故障排除帮助。
219等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
12条评论
This article needs to be vetted. There is a very specific type of hard drive needed for this machine. Also, the machine will need to be backed up to either the PS Network(for PS Plus members) or a removable storage device. Additionally, the latest system update must be available after the new hard drive is installed. Below is an excellent article for this procedure.
can I take out my 500 gig and put in a 1 tb or no ?
Hey Phil,
Yes, you can. I have successfully replaced the original hard drive with a 2TB hard drive I purchased. Just make sure you buy the correct type of hard drive. I recommend using the article Kenneth has linked above in the comment section: http://www.ign.com/wikis/playstation-4/H...
I backed up my saved data on the PS network instead of using an external hard drive and that worked great.
Enjoy the extra storage!
Yes you can upgrade to 1TB or even bigger. Last PS4 firmware update was in august, and it supports storage up to 4TB. You can also use bigger storage but it may result in error.
You can update 2.4-internal HDD or use something like Nyko data bank to use 3.5 inch drives. Also external hard drives is an option, but in order to use them you will need to install the software and games on it.
ps4 hard drives:
