跳转到主内容
更换PS4的WIFI无线天线模块
你所需要的
  1. 更换PS4的WIFI无线天线模块, 翻转PS4: 步骤 1 中的图像 1,1
    • 翻转PS4,底部朝上,背部插口区向你
  2. 更换PS4的WIFI无线天线模块, 移除保修贴纸: 步骤 2 中的图像 1,3 更换PS4的WIFI无线天线模块, 移除保修贴纸: 步骤 2 中的图像 2,3 更换PS4的WIFI无线天线模块, 移除保修贴纸: 步骤 2 中的图像 3,3
    • 移除后部中间的两个保修贴纸,可以看见两颗螺丝
  3. 更换PS4的WIFI无线天线模块, 移除螺丝的塑料盖子: 步骤 3 中的图像 1,2 更换PS4的WIFI无线天线模块, 移除螺丝的塑料盖子: 步骤 3 中的图像 2,2
    • 移除每个边角的塑料盖子,可以看见螺丝
    What If my PS4 doesn't have the two screws on the side
    Michael Jimenez - 回复
    I should imagine that plastic cover will come off?
    How did you go?
    Cary B -
  4. 更换PS4的WIFI无线天线模块, 拧下后盖螺丝: 步骤 4 中的图像 1,2 更换PS4的WIFI无线天线模块, 拧下后盖螺丝: 步骤 4 中的图像 2,2
    • 取下4个7.2毫米的内六角螺丝
    I only have two screws, those in the middle of the console.
    Oscar Martinez - 回复
    Have you removed the plastic covers mentioned in the previous step? That will expose the other two screws.
    Sam Omiotek -
    same, here. there are only the middle screws, no covers or screws on the sides. and it sits pretty tight
    Johannes Müller - 回复
    turns out 12XX models are different. Look at this for reference: https://www.youtube.com/watch?v=Hpr0z0ve...
    This video guide is very useful, thank you. The disc drive itself is different than this ifixit guide too
    UnitedShoes -
    Yes there is slight variations between the first models, and the second gen and on models. I have an original and only has the two screws in the middle, removal of the cover remains the same.
    Mary Westphal - 回复
  5. 更换PS4的WIFI无线天线模块, 拆下底壳: 步骤 5 中的图像 1,2 更换PS4的WIFI无线天线模块, 拆下底壳: 步骤 5 中的图像 2,2
    • 在此插入翻译用拇指向上顶起底壳并取下。
    • 此底壳为塑料卡扣结构,移除时需要一些巧劲。
    sur la version 2 de l ps4 fat il n'y a que les 2 vis du milieu. Comment défaire le boîtier ?
    nlvolle - 回复
  6. 更换PS4的WIFI无线天线模块: 步骤 6 中的图像 1,2 更换PS4的WIFI无线天线模块: 步骤 6 中的图像 2,2
    • 用镊子拔出电源供给接口,使之与主板断电。
    • 如果感觉电源连接器被卡住了,用撬棒轻轻地把连接器撬出来。
    This part looks dangerous. There should be a flag/warning not to destroy that cable yes?
    Shawn - 回复
    I second Shawn's comment. That cable seems to be very fragile, and one of the wires snapped on mine while removing the cable. It wouldn't have bothered me so much, if it wasn't a pain to find a replacement for it.
    Matt Gaia - 回复
    The tweezers used here, do not cut it. Not enough grip.
    I had to use a set of needle nose pliers to remove this.
    Cary B - 回复
    Power supply connection stuck. I don't want to damage it
    Nick Alex - 回复
    What you need to do here is be patient. Do not pull the wires. Get some fine nosed pliers, wiggle the white connector from left to right in small movements and edge it out slowly. You can also use your nails one finger at each edge of the white connector to do this.
    David Harkness - 回复
    Its really hard but i managed it with both of the tweezers/pincers at the same time
    1. Keep in mind to pull not too hard on the wires and make step 2 and 3 simultaneously!
    2. the straigt and wider tweezer to pull the white connector itself
    (top and bottom grip)
    3. the small and angled tweezer to pull the wires carefully
    (as shown on the picture above)
    dinkelberg01 - 回复
    Another option, is to remove the screws holding it down, leave the cable in place and lift it out carefully, revealing the other end of the connection. The hidden side of the connection wire is easier to get a handle on.
    Mary Westphal - 回复
    I concur with David, some patience and a lot of wiggling did it for me despite the stubbornness of the connection. Does seem like this one varies a lot in how difficult it is to remove.
    hazelrat - 回复
    My connector wouldn't budge no matter how much I wiggled it. I solved it by lifting the power supply out and disconnect the connector at the other end (mainboard end)
    _I_ - 回复
  7. 更换PS4的WIFI无线天线模块, 卸下电源装置: 步骤 7 中的图像 1,2 更换PS4的WIFI无线天线模块, 卸下电源装置: 步骤 7 中的图像 2,2
    • 卸下三个 9.7 mm Torx 安全螺丝。
    • 卸下两个 41 毫米十字螺丝和支架。
  8. 更换PS4的WIFI无线天线模块: 步骤 8 中的图像 1,3 更换PS4的WIFI无线天线模块: 步骤 8 中的图像 2,3 更换PS4的WIFI无线天线模块: 步骤 8 中的图像 3,3
    • 将电源直接向上提起并从 PS4 中取出。
    • 电源通过左侧的插脚牢固地固定到位。可能需要多次尝试才能将其移除。
    • 在重新组装期间,确保插脚对齐,然后将电源按入到位。
    How do you remove the battery wires? I’ve personally been wiggling it to no effect, is there a certain way i have to pull it out, and should i pull it out of the power supply or the console?
    Tubby - 回复
    Retirar en vertical, derecho hacia arriba. Sino puedes doblar uno de los tornillos largos
    FabianCampos - 回复
  9. 更换PS4的WIFI无线天线模块, 取下 Wi-Fi 天线: 步骤 9 中的图像 1,2 更换PS4的WIFI无线天线模块, 取下 Wi-Fi 天线: 步骤 9 中的图像 2,2
    • 使用撬棒的尖端从主板上断开天线电缆。
    dumb question but I’m very new to this. when reconnecting the wifi antenna, does it just click back on? I'm hesitant to try this procedure if I need to solder anything since I have zero experience.
    cliodhna - 回复
    Yup! Hold it in place and press straight down on top of it with your finger or a spudger. If you have any other cable/connector questions see this guide.
    Sam Omiotek -
    Heads up, you might have a black philips screw above the power connector. It fixes the motherboard and EMI shield on if you're dealing with an 1100 model.
    Dzmitry - 回复
  10. 更换PS4的WIFI无线天线模块: 步骤 10 中的图像 1,3 更换PS4的WIFI无线天线模块: 步骤 10 中的图像 2,3 更换PS4的WIFI无线天线模块: 步骤 10 中的图像 3,3
    • 使用镊子或手指抓住天线电缆并将其从电缆导轨中取出。
  11. 更换PS4的WIFI无线天线模块: 步骤 11 中的图像 1,3 更换PS4的WIFI无线天线模块: 步骤 11 中的图像 2,3 更换PS4的WIFI无线天线模块: 步骤 11 中的图像 3,3
    • 使用镊子或手指将天线电缆从光驱电缆下方穿出。
  12. 更换PS4的WIFI无线天线模块: 步骤 12 中的图像 1,2 更换PS4的WIFI无线天线模块: 步骤 12 中的图像 2,2
    • 卸下固定天线的 9.7 毫米 Torx 安全螺丝。
    This does not work on the newer 12 series
    raseemhassan123 - 回复
    Thank you! I thought I was insane. I've been trying to figure out where the hell this thing goes and the seat for it is like an inch from the corner. It's driving me mental trying to figure out how to put this back on
    Leo Halliwell -
  13. 更换PS4的WIFI无线天线模块: 步骤 13 中的图像 1,2 更换PS4的WIFI无线天线模块: 步骤 13 中的图像 2,2
    • 取下 Wi-Fi 天线。
    When I’m connected to wifi it does good for awhile then it disconnects from the wifi and I can’t use the controller. I have to turn the game off and disconnect power source. Do you think the wifi antenna could be the problem or doin have another situation.
    Jay Pax - 回复
    I would check the antenna connection to the motherboard, if it's properly seated I don't think it's the problem.
    hazelrat -
结论
要重新组装你的设备,请按逆序执行上述步骤。
将你的电子垃圾送到 R2 或 e-Stewards 认证回收商
维修没有按计划进行?查看我们的 Answers community 以获取故障排除帮助。
将你的新更换零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
89等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Sam Omiotek
于02/25/19注册
72,571 声望
创作了288篇指南
111条评论
Took me about 10mins with this guide. Super easy. New parts in and working wonderfully. Ty ifixit!
luckycha87 - 回复
My wireless controlers wasn't recognised. I change the WiFi connector but this problem is not resoleved yet.
Frederic Morelli - 回复
Hi Frederic! Have you tried resetting the controller? Have you tried any other controllers to see if they work? Also, are you sure the battery in your controller is good and it's charged up?
TronicsFix -
Hello my controller has a hard time working from 4 feet away from my console and disconnecting. Im thinking of doing this hopefully it works. Is the bluetooth and wifi part the same thing because my wifi doesnt seem to pick up my wireless router.
ludracing - 回复
Yes, the wifi and bluetooth antenna is the same.
TronicsFix -
Hello, my controllers are connecting and disconnecting as well, but also with the USB cord attached... The buttons and responses are very laggy and erratic... Is this caused by the same issue? Would there be outside damage to the cord that is noticeable or perhaps not? Thanks for any and all help! Its happening with all 3 of my controllers by the way. They are all charged that I know ( left on USB all night in rest mode)...
-Lionel
Nel - 回复
Yes, this could still be the same problem. Even with the USB cord attached they still communicate via Bluetooth.
TronicsFix -
I dismantled my PS4 (to fix the fan problem). Upon reboot after rebuilding it, it either doesn't at all recognise my DS4, has awful latency or has other problems like this. Would putting a new WiFi receiver in fix this?
Callum Berryman - 回复
It's hard to say...I'm assuming that it didn't have this problem before you took it apart so there is likely something that has been damaged that is causing this. Since I don't know what that is it's hard to know whether replacing the WiFi antenna will do any good or not.
I would go back and check to be sure that you remembered to hook it back up to the motherboard and that the connectors are good. Just retrace your steps.
You can take a look at the end of the antenna and see if it's smashed as well as check to make sure that the wire itself has not come unsoldered from the antenna.
I hope this helps.
TronicsFix -
But is it reasonable that this piece affected the small Bluetooth device
Anwar - 回复
Yes, this is the WiFi & Bluetooth antenna
TronicsFix -
Hello! I am about to attempt this but was curious- if the wire is just disconnected, can I simply reattach and solve the problem? Is there a way to tell if the antenna is failed vs. just not connected well?
arizonaluke2 - 回复
You could just fix it in most cases if you know how to solder.
TronicsFix -
The problem of lack of control is not connected to wifi antana but there is a piece aluminum in disbelief inside does not relate well to the Bluetooth device, you must be expanded up to reach to control long distance
Anwar - 回复
Why does that antenna look different then mine?
Javier Exford - 回复
Hmmm...it should look pretty similar. Is yours drastically different?
TronicsFix -
Where can I buy a replacement antenna
Kali - 回复
I'm having issues with my controllers where they will lag and not respond when pressing a button. They also disconnect from the ps4 and are fully charged. I opened up my ps4 to clean out the dust and accidentally bent the WiFi antenna. Will replacing the antenna fix the problem?
Omar Reyes - 回复
Most likely, yes
TronicsFix -
Hi,
Quick question: if I remove the wifi antenna, do I have to use wired controllers? Also, can I be sure there is no more wifi signal at all, so only internet access possible with cable?
Thank you!
Greetings, Dave
Dave - 回复
If you remove the WiFi antenna you would have to use wired controllers most likely. They might work within a short distance though. There will still be a WiFi signal even without the antenna. The antenna just helps to pick up the signal from a long distance.
This is actually a WiFi/Bluetooth antenna and since the controllers use the bluetooth signal even when plugged in they may not work correctly.
TronicsFix -
ok, thank you very much for the quick reply!
Greetings
Dave - 回复
Got my part in a week from when I ordered it. Very fast manner and the instructions were perfect. I already knew how to open the bottom cover but not the power supply. The antenna works great. Took me less than 5 minutes.
Julie Lorenz - 回复
Glad it worked for you!
TronicsFix -
My advice is that if you open the bottom of your ps4, be careful not to clip the antenna. I think it a ridiculous place to put it on the console.
Julie Lorenz - 回复
Yes, it's not the best placement as far as keeping it from getting damaged, but as far as reception it's a pretty good spot.
TronicsFix -
hi my ps4 controller is not geting connected in game mode but in safe mode it works with wire conected . is thr any solution of this issue ?
harry tom - 回复
It's hard to know for sure without seeing it but you might need to have the wifi module replaced. It's not an easy job since it's attached by solder balls under the module.
TronicsFix -
hi !I live in mexico .... but you could bring me the antenna to mexico ? Obviously if I buy... which it costs 13.99 dollars
dothonrojasglz - 回复
If I take out my PS3 Bluetooth antenna and put it in my ps4 would it work?
Joey Anderson - 回复
Unfortunately a PS3 antenna will not work for a PS4.
TronicsFix -
Excuse me, i got a problem with my ps4. It can't detect my wifi router, does it mean my ps4 wifi antenna broken? This antenna not just for ps4 controller? Thanks
archangelfei - 回复
Hmmm...usually a broken WiFi antenna can still connect to a router just fine. I'm really not sure why it wouldn't be able to detect it. I'm assuming you've checked to make sure your router is working correctly and can connect to other things. It's possible that it's a bad WiFi card on the motherboard but that's not likely.
TronicsFix -
After doing the fan replacement, i can't get my internet connection to work. I can see my router in the ps4 menu but i can't get it to connect. I'm from Germany so it's in german but it says: "Verbindung in der erlaubten Zeit nicht möglich" something like "connection is too slow" can anybody help? the problem isn't related to my WLAN-router and now I'm thinking that I may have destroyed it but the cable is connected and as I said I can see my Wifi in the menus.
justblazeiv - 回复
I'm not sure what the problem would be. Usually even if the wifi cable is broken it will still connect to wifi. That being say it's definitely possible that a bad wifi cable could cause this problem.
TronicsFix -
My PS4 won't detect my controllers from any distance, but the wifi works just fine. Is it possible that the antenna is the problem even though the wifi works?
I've tried virtually everything else but replacing the antenna or the module. The controllers stopped working suddenly when I was installing a game.
gustavo - 回复
Does your controller work when it's plugged in? Have you tried another controller? Does it work when the console is in safe mode?
TronicsFix -
Thanks for the reply.
Yes, the controllers work fine in safe mode and in other consoles (and even on my PC/phone via bluetooth). I can still access the console through the PS phone app, and when I connect the controllers by cable, the DS4 pops up in the devices window, but they don't pair via BT. I've also tried searching for the BT signal the console should be emitting, but I couldn't find anything (and I'm not sure I should find something in the first place).
gustavo -
OK...it sounds like maybe your BT module may be faulty...there's no way for me to know for sure...that's just what I suspect.
TronicsFix -
Hello!
Hello! I'm using my PS4 through cable internet connection and I bought a thirdy party controller (Hori Pad FPS Plus) to get a wired controller, so apparently the console is completely wired.
I did so because I unfortunately got skin problems from iPads and other wireless devices. Could you please tell me if the console still emits wifi or BT radiation, and if I could prevent that in the case? Thanks!
giuseppespera - 回复
Hi! Wow...I've never gotten a question like this before! Um...I think it will still be emitting a signal but I can't say for sure. I think the only way to totally disable it would be to remove the WiFi/Bluetooth controller or remove the power to it. I've never done that before so I can't say for sure if it would work but I think it would.
TronicsFix -
Hi, Ive just recently bought a new wifi antenna, and looking to replace it using your guide. But i dont really get how to put the new one in, is it just like a click thing? or do i have to do something else to replace it ( because the guide stops where u remove it). Maybe its a dumb question but im not that experienced in this matter.
Thanks for the guide!
bram ver - 回复
Yes, it just clicks onto the connector on the motherboard.
TronicsFix -
Hi I had input lag from my controllers. I replaced the antenna (bought the new one here) but I am still having the same problem. The controllers work ok at first and 5 minutes into the game they statt presenting lag and going all to the right or leg in occasions. Please help, what else should I do. My ps4 is quite new
angellom90 - 回复
If it's pretty new then I would send it in for warranty repair. If it's not under warranty it's hard to say for sure what it is without being able to see it. I'm assuming that you installed it corrrectly. I would check it with multiple controllers. You may try initializing it as well.
TronicsFix -
So I bought a console on ebay and I'm afraid it got damaged during shipping. It looks like it took a hit on the corner under where u load the disk. My 2 controls have connections issues, lag, and seem to only kind of work if theyre right next to the console. It'll connect to the Internet via ethernet cable but my WiFi won't come up when I try to connect that way. Do these sound like problems stemming from the WiFi antenna? I'm hoping it's an easy fix.
jorion1118 - 回复
Yes, sounds exactly like a WiFi antenna issue. It's very common with dropped PS4's.
TronicsFix -
Is the part that connects to the cord suppose to connect to the ball next to it?
Jonathan Butler - 回复
The WiFi cable snaps on to the connector on the motherboard.
TronicsFix -
In the picture Above, the second below the big picture it's the part the metal part close to the thumb in the picture. Is the metal piece suppose to be attached to the metal piece with the cord connected
Yes, it is soldered onto the other piece.
TronicsFix -
Mines is connected. Trying to see if I should buy another controller or is that why my controller isn't working. Don't have enough for both
Jonathan Butler -
Sorry I meant isn't connected
Jonathan Butler -
Yes, that's why your controller isn't connecting. That's the wifi antenna so that's what's getting the signal from your controller.
TronicsFix -
Hi, my DS4 controller will not connect at all. I have tried everything. I truly mean everything (aside from opening up the console and replacing the wifi antenna or module) The controller's Bluetooth works fine on my PS3 so the problem is obviously the PS4 console. The connection was lost mid game and was never an issue in the past. Also, the controller will not connect no matter how close it is to the system. I feel like this issue is most likely the module. Do you agree? Do you have a step by step guide for unsoldering and resoldering the module? Are there any tips or suggestions you might have? Any help would be greatly appreciated. Thank you!
Jordan Belsky - 回复
Yes, it's likely the module. Unfortunately, I don't have a guide for that. It's always easier when you have a good quality hot air station. I use a Hakko FR 810b-05. Good luck.
TronicsFix -
Buna am o problema cu ps4 al meu nu mi gaseste routerul din casa sa se conecteze . Am facut tot felul de restarte la router , ps4 , initializare , rebild database etc. si nimic ce ar putea fi ? Va rog ajutatima.
nelu kostraba - 回复
I was wondering because I don't know what to fix-
My ps4 controller is fine the only problem is that my Ps4 console won't connect to my internet but it's right next to the router and all other devices connect (iPhone, Mac, iPad, etc.) and it won't allow me to access the PlayStation store to download games so whats the problem? Do I fix the wifi antenna or is it something else ?
garrett walker - 回复
Ps4 controller won't connect to console, the controller works fine on other consoles. Only time the controller works is when the console is in safe mode and connect via Usb. Would this be wifi antenna problem or more serious issue?
Shadane - 回复
This type of problem is not usually a WiFi antenna problem. Sometimes it can be caused by a bad WiFi card on the board and sometimes it can be caused by faulty software.
TronicsFix -
@tronicsfix thanks for the feed back, so what's the fix for this problem if there is any?
Shadane - 回复
That just depends on what the problem is. If it's the WiFi card on the motherboard then yes, that's fixable. If it's a software related issue then it's probably not fixable.
TronicsFix -
I seem to be having internet speed problems over my ps4 wifi. I currently pay for 50mbps and my system speed will go from 18mbps up to 47.8mbps. does that sound like the wifi card in my ps4 is going bad or do you think its the modem having issues? Any help would be appreciated.
dpiatt6@hotmail.com
Don - 回复
I doubt it's your WiFi card. My guess would be that you don't actually get the speed you pay for. It's very common for people to pay for a certain speed that they don't actually get.
TronicsFix -
Thank you! I took apart my PS4 2 years ago to replace the power supply, which wasn't the issue. I recently found a YouTube video which had a crazy easy fix for my issue that worked. Problem is when I reassembled I got it working but connectivity of my controller would NOT work. Tried everything. Then I saw your article and rechecked the Bluetooth adapter wire back under the power supply and found it was disconnected! I never would have thought to recheck that after two years. Thanks again for the easy fix!
lpa_weisel - 回复
Cool! Glad this helped!
TronicsFix -
think the wifi/bluetooth module is broken on my PS4. I'm going to fix it myself (or rather have a friend do the soldering job). Do you have any recommendations for the replacement module? I've read about different distance ranges for different bluetooth chips but don't know enough about them to feel confident about choosing one.
Robert Sommer - 回复
I don't know anything about replacement modules other than the stock ones.
TronicsFix -
I'm considering getting a new Wifi antenna for my PS4, but I want to make sure it is the problem before buying a new one. I do not have a problem with connectivity to my controller; it is only the Wifi connectivity. Even being the only person in the house, I still run about 1-4mbps and sometimes I lose connection even when I am no more than about 30 feet from the router. Does this sound like an antenna problem or internet provider problem?
Chaz Bogan - 回复
Sounds like probably not a WiFi antenna issue. Most of the time the controller will be disconnecting and acting erratic, etc. when the antenna is bad.
TronicsFix -
My Ps4 recently giving me errors that my Wifi signal is too weak. In setting up the connection it will detect the wifi just not be able to connect to it. Controllers work fine and my router has been restarted multiple times. All other wifi devices in the house work perfectly and my ps4 did as well. I think this antenna is the issue but could it be anything else?
Christopher DeLucia - 回复
I doubt it's the antenna. If the controller is working fine then it's most likely not the antenna.
TronicsFix -
I'm have an issue where if I have a headset plugged into my controller the audio cuts in and out and it causes my controller to stop working when the audio is cutting in and out. I just replaced my wifi/bluetooth antenna but I'm still having this issue, what else could be causing this issue?
Dereck Ward - 回复
Maybe you try with another controller.
Thomas Pathe -
You're kidding me right? You actually think I haven't already tried that, I even bought a new controller and it still does it.
Dereck Ward -
So if the Wi-Fi antenna to the PS4 is broke it doesn't like to work properly the paddle
michaelmccullen57 - 回复
HI, I am the repair tech at a small console repair business and i have an cuh-1215a ps4 that is not responding to any controller input unless in safe mode and my research showed that it was the WiFi/Bluetooth chip on the board that was faulty. i tested it with controllers at the facility and it wouldn’t sync with any of them even on a wired connection. when the ps4 was in safe mode it accepted input but never showed that the remote was synced. now, is the chip faulty or is it a deeply ingrained firmware bug? i’ve already re-flowed the chip and that had no effect, I am at the point where i am going to replace the chip and hope for the best. a rapid response from a more experienced repair facility would be most appreciated. your videos on youtube have helped me with many a diagnosis. thanks
Pawn Plus - 回复
hi, im looking to buy a wifi antenna replacement for my original ps4. Do you guys have any that arent used and are brand new? i would like to purchase one.
himd himd - 回复
No, sorry. I don’t know of anywhere to buy them brand new.
TronicsFix -
Also if i cant buy a new one from you guys can you point in the direction to where i can get one .
himd himd - 回复
I replaced the fan in my ps4 and accidently broke the connector that attaches the antennae to the motherboard. I soldered it but did a crappy job. Now the controller will only work when I'm 2 ft. Away from ps4. Should I purchase a new antennae and just resolder to the motherboard? Is there another way to fix this? Suggestions?
Jason Langley - 回复
The only good way to fix this is to get a new connector and solder it onto the board correctly. That’s the only good way that I know of to do it.
TronicsFix -
Directly connected with my 4 foot USB charger I have no lagging, my 15 foot USB charger plugged in I have lag, and no charger I have some lagging. My head set plugged into remote I find the audio cutting in and out, unplugging it the audio from the TV works fine. Some lagging on the main menus screen. Two brand new remotes. I’ve disabled any devices that work with Bluetooth or WiFi (cell phones, tablets, laptops) which seemed to help a little bit. Would an new antenna help out in my issues? While replacing my antenna, should there be anything else I should replace/upgrade/look in to? Thanks
Charles - 回复
Hi, thanks for the guide. My problem is the controller doesn’t work from more than 1 foot away, it starts to lag and disconnect frequently.
However, My wifi works pefectly and isn’t effected at all. Is it still the antenna causing the issues with my controller?
thanks
Js Sj - 回复
Yes that would still be the antenna most likely.
TronicsFix -
''Hi there, can't get past “press home button on controller” to get into safe mode. Controller flashes twice then turns to charge mode. Have tried different wires, controllers etc. Can still turn ps4 on with controller from any distance just can't get past that screen, please help, im this close to smashing it up and sending the bits to sony
R2DTARD - 回复
Hi Austin,
you should try to connect the controller with a usb-cable! Maybe the controller is not connected to your PlayStation
Thomas Pathe -
Thats what i meant by trying different wires all were usb 3.0 and new. And both controllers are definitely connected hence being able to turn on the ps4 from distance connected and not connected.
R2DTARD - 回复
I replaced my antenna today with this guide with a stronger antenna….this one https://www.amazon.com/dp/B00DMHSODS/ref...
I have my ps4 hardwired, so this was for extending my controller range, which it didn’t seem to do at all….any tips on what would have gone wrong? The replacement is complete and the controller has just about exactly the same range and is responsive. I’m certain I replaced the antenna in this guide and made a mode to run the line for the linked antenna out the side of the PS4…any tips on extending controller range?
Robert Granholm - 回复
my ps4 stopped connecting to wifi a while ago, uses an ethernet cable fine tho, and now my controllers are laggy and unresponsive. could this fix both issues?
Leland Cox - 回复
This solely fixes WiFi issues, the Bluetooth module is soldered to the motherboard. So if you are having connection issues with your controller this not going to fix that. Also, this is only going to give you back the ability to connect to a 2.4 GHz network, NOT 5 GHz!
christopherramoutar -
This will eliminate unhealthy radio waves? I use ethernet and wired controllers, but the xbox one needs the wifi card to be physically removed anyway in order to eliminate harmful radio waves, I assume ps4 has the same design failure.
Scarlet Jester - 回复
this made the replacement sooooo much smoother than it could have gone otherwise! thanks!
Joe Rather - 回复
if replacing this part dose not work what are my next steps? (i ordered the part i just wanna be ready for worst case)
Jesse - 回复
Hello, my ps4 possibly got dropped (I’m not quite sure) and suddenly the wifi completely cuts out for 1 second on my PS4 and only my PS4, once an hour. Super annoying, especially playing online games because you get kicked. Would this help? Is it possible my antenna got damaged or no?
Almand - 回复
Where does the Wifi antenna attach to the motherboard. I was changing the fan and went to put the motherboard back in and the wifi antenna broke off it
john degges - 回复
I disconnected the pin that holds the antenna… how can I fix this?
yankeecpt - 回复
Can this wifi antenna work to make my original ps4 work with 5 GHz? And it does it support the connection on the same older controllers? I just want to find out before I buy it.
biteme93 - 回复
Hi, when I get to the “Press X to Start” screen in any game, the controller stops working and I need to turn it off and turn it on again for make it work. And that happens every time when I change between games screen and menu screen. Do you think I can repair it changing the wifi antenna?
alan.acero36 - 回复
I know this is older but I was wondering if this might be a fix for a PS4 that is no longer connecting very well to WiFi internet? It used to connect well and other PS4’s connect just fine, but I have one now that the WiFi connection is very poor no matter where we put it.
Bert Beattie - 回复
Hello..
Iam having an internet problem..
I try connect but many time after a long time say internet connection failed..
Some times say i ternet connection success but when i try yo load an image in the browser or try connect to PSN say time out and no load any page or do somethink..
Is the problem the chip of internet indife the console?
Πανος Ρουσόπουλος - 回复
Very easy to follow, performed my repair very fast thanks to this!
xXxxxX - 回复
Moin,
super Guide.
habe die Antenne getauscht, habe aber W-lan technisch keinen Unterschied gemerkt. Habe mal zu testzwecken die Antenne abgenommen und den Netzwerktest gemacht. Ergebnis war Controller verliert die Verbindung aber Internet Geschwindigkeit ist gleich wie mit Antenne. Woran kann es liege? Falsche Antenne an dem Anschluss angebaut?
mit freundlichen Gruß
Marcel - 回复
hi if i want to remove the antenna so that the console cannot ever connect to the internet will i be able to use my controllers plugged in or they wont work at all?
heidi - 回复
Does this also chage the mac adress? because apparently my isp blocked my mac adress, and im still trying to find a way to change my mac adress if possible. ISPs been very greedy nowadays
Bagas Catur S - 回复
Hello! My PS4 has been having connection issues over Wi-Fi. It is the only device that has these issues, where it struggles to get above ~60 kbps speeds, while my other devices get speeds of up to 30-40 mbps. Is this an issue with the Wi-Fi antenna or the Wi-Fi card on the motherboard?
koog - 回复
When I go away from my PS4, the controller disconnects, if I replace WiFi antenna, will it be ok?
Mohammad Reza Safari - 回复
i think that it is maybe the bluetooth chip
doude76 -
I think that it is possibly the bluetooth module
doude76 - 回复
Hello, my ps4 can only hold a wifi connection for about 5-10 minutes then it will loose it. My wireless controller keeps a connection to my PlayStation just fine. If I test for a wifi connection, it’ll reconnect with 100% strength and then loose it again after 5 or so minutes. If I leave it, it will reconnect after 10 or so minutes. If I replace this part, will it fix the problem? And no, it’s not my internet because my phone, laptop, and other devices are not having this issue.
Valkiery - 回复
添加评论
浏览统计数据:
过去 24 小时: 47
过去 7 天: 189
过去 30 天: 1,086
总计 164,909
