简介
这篇指南将会帮助你替换任天堂Switch左Joy-Con手柄的按键。请注意这篇指南并不包含一些右Joy-Con的步骤。右Joy-Con的一些地方更加复杂。替换左Joy-Con按键的步骤包括打开Joy-Con,拆除内部的部件、电池和转。然后移除并更换目标按键。
你所需要的
轻轻将电池的接头从主板上拉开。(也可以用撬棒撬开。)
This step is very precise and it is easy to break the connector if done incorrectly.
Yeah I broke it… it would be nice to see a more in-depth version of the video on their YouTube.
Rosie -
So lucky I had one to "dissect" turns out you don't pull in line with the wire it's more of a pry up/pull straight up from the board
用飞利浦#2十字螺丝刀移除红圈处固定电池仓的三颗螺丝。
There is also a phillips screw in the bottom right of the picture that needs to be removed before removing the battery holder.
Ben Masten - 回复
用镊子将五个排线插座上的黑色固定夹向上掀开。
用镊子将排线轻轻拽离插座。
I use these tutorials to also learn what each part is so I wish these were labeled with their proper names
要想组装你的设备,按照相反顺序操作即可。确保你在拧主板螺丝的时候没有拧的太紧,否则按键有可能会保持按下的状态。
30等其他人完成本指南。
由衷感谢以下译者:
89%
mallow正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
My left directional button is nonresponsive. Can I fix this by dropping in a replacement left directional button? Would the rubber cover need to be replaced as well?
just incase you havent done so already, it might not be the button. it might be the motherboard, connectors, and a whole slew of other problems.
What type of switch is the minus button? It’s on the same ribbon as the L micro switch. My L switch is bad and I’m replacing it I just would like to know the name of the type of switch used on the minus button.
Thank you for the helpful guide! Is there a guide for the right Joy Con available anywhere?
ericsajedi - 回复
Eric, no one has made a guide for the right Joy-Con yet! I’ve taken them both apart and the buttons are pretty similar. I think you can use Joshua’s button guide here and this joystick guide to guide you to the buttons in the other Joy-Con! If you do end up attempting it, consider taking some photos and making a guide for future right Joy-Con fixers. :)
Thanks for sharing this awesome guide! The first Joy-Con repair went great but i just tried repairing a second Joy-Con and after calibrating it’s drifting really bad. The replacement joystick I used was from Amazon and only $6 so I’m assuming that’s why it didn’t work. I just ordered a new replacement joystick from iFixit so hopefully that one is better quality and works. Thanks again!
ericsajedi - 回复
Mon bouton left ne fonctionné plus , problème résolu grâce à ce tuto ,trop simple en faite .
