简介
这篇指南将会帮助你替换任天堂Switch左Joy-Con手柄的按键。请注意这篇指南并不包含一些右Joy-Con的步骤。右Joy-Con的一些地方更加复杂。替换左Joy-Con按键的步骤包括打开Joy-Con,拆除内部的部件、电池和转。然后移除并更换目标按键。
你所需要的
要想组装你的设备,按照相反顺序操作即可。确保你在拧主板螺丝的时候没有拧的太紧,否则按键有可能会保持按下的状态。
30等其他人完成本指南。
由衷感谢以下译者:
89%
mallow正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
My left directional button is nonresponsive. Can I fix this by dropping in a replacement left directional button? Would the rubber cover need to be replaced as well?
just incase you havent done so already, it might not be the button. it might be the motherboard, connectors, and a whole slew of other problems.
What type of switch is the minus button? It’s on the same ribbon as the L micro switch. My L switch is bad and I’m replacing it I just would like to know the name of the type of switch used on the minus button.
Thank you for the helpful guide! Is there a guide for the right Joy Con available anywhere?
ericsajedi - 回复
Eric, no one has made a guide for the right Joy-Con yet! I’ve taken them both apart and the buttons are pretty similar. I think you can use Joshua’s button guide here and this joystick guide to guide you to the buttons in the other Joy-Con! If you do end up attempting it, consider taking some photos and making a guide for future right Joy-Con fixers. :)
