简介
作者:我的盖乐世S6 Edge用了几个月的某一天,我发现拍摄的照片模糊不清。这时我翻过手机一看,相机玻璃碎了。
你所需要的
24等其他人完成本指南。
由衷感谢以下译者:
100%
Z.Heng正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
22条评论
I think they have the exact same camera. See:
http://www.gsmarena.com/compare.php3?idP...
Im going to buy it and try it myself. I'm sure if you wanted to replace the entire camera, you'd have to get one made for that phone, but this is just the lens, so I'm sure they're the same size and dimensions.
Was your camera blurry when it was damaged as mines smashed and camera works but won't focus.. any help anyone please?
Did you ever get a reply to this? I am having the same issue
Sorry I didn't see this earlier.
My camera was a little blurry, but I found out that was due to being dirty and some condensation.
Before I replaced the back camera lens I cut a small corner off of my lens cleaner cloth for my glasses. I used a pair of tweezers and the same cleaning solution to clean the camera lens. If you think the camera needs repaired, you could replace that at the same time. It would go beyond the scope of my guide but I did see the part was available for purchase.
shicks -
where did you get the replacement glass, all i can find if the whole camera set up
Ok here is the problem, i have dust under the glass, can i heat it up and remove only the glass and then stick it back in? there is only one glass part ? there isnt another one from the inside of the frame?
Where do you get the right size tape ring?
One comes with the piece of glass here.
http://www.witrigs.com/oem-camera-glass-...
This is the one I used.
shicks -
Perfect. Thanks!
It's the same process to replace on the regular s6?
hello sir
my name is binay rai and i have same problem i have cracked my glass but while capturing photos i have dark particles? may i know what that is? amd how to remove it? please
It is condensation in the camera causing the spots. You will need to remove the back cover and replace the camera to get rid of them.
What is the best way to protect my now exposed camera while i wait for the replacement lens glass?
Bobby Ward - 回复
Put a piece of tape over the hole until your glass arrives. It may be good to tape a thin piece of cardboard over it.
If my camera view has a bunch of purple/black spots on it and a bit blurry, then I probably need a whole new camera huh?
Yes, it is condensation in the camera causing the spots. You will need to remove the back cover and replace the camera to get rid of them.
how do I determine whether or not I need just the glass replacement or a whole new Camera replacement.. I smashed the glass heavily on something and when I open the camera app It still works just won't focus? is replacing the glass help it focus or what?
Try removing the glass and once you’re sure all the glass pieces are out, open the camera app and see if it focuses. If it has spots or defects, you may also need to replace the camera.
