简介
从你的盖乐世S6上卸下后部玻璃面板并去除将其固定到位的粘合胶。参考本指南以更换盖乐世S6的后部玻璃面板上的粘合胶。大多数粘合胶如步骤中那样是配套的,然而有些膜尺寸和颜色可能会不同。
在开始之前,我们建议你将玻璃面板上所有残留的粘合胶清理掉。可以使用棉签以及溶剂如异丙醇来清理。
你所需要的
141等其他人完成本指南。
由衷感谢以下译者:
83%
Z.Heng正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
9条评论
It would be handy to tell us a reliable place to obtain the adhesive from as iFixit doesn't appear to stock it
I snagged a replacement front and back glass adhesive and a new daughter board for the S6 from http://www.mobiledefenders.com/. They seem okay so far. Only about a buck for the adhesives, plus shipping.
Will the adhesive for a galaxy s6 work on the back cover of an s6 edge?
It won't work. Size is different. One for S6 is larger
Jimmy -
Couldn't you just cut it to size? If it's just a pad of adhesive, you should be able to just cut it to the smaller backing size. I'd assume it's non conductive, but make sure it's not blocking anything important.
Ampera -
amazon has the S6 film
While cleaning off the old adhesive the rear housing broke into 3 pieces??!! I was using a kitchen table place mat….I would have appreciated the author giving me a heads up on how fragile the rear cover is.
It’s glass. That should be warning enough.
