简介
首先要打开它,很难修复任何东西。
你所需要的
使用撬棒从电池和电池仓中取出大部分液态电工胶带。
This is NOT liquid Electrical tape! I recommend using 3M adhesive silicone. If you are doing this repair then you can find the 3m adhesive silicone at automotive stores. Liquid tape hardens and 3M adhesive remains mailable vs the rock hardening effect of liquid tape.
用PH2螺丝刀从白色塑料外壳上拆下剩下的四颗16mm十字螺丝。
The two screws on the right side (side with the USB port) are too long to extract with the iFixit screwdriver in the basic kit. I needed to use a regular thin PH2 screwdriver to get them out.
I had this problem also, whenever putting the screws back in there were still air pockets in the side with smaller screws
一旦设备打开,请断开主板上的三个白色连接器。
分离两个套管。
Hi , Thanks a lot in my speacker i had broken plastic part which affect clear sound with your guide i open mine seasily and take it out now i have beand new sound which i had before. thanks again.
要重新组装您的设备,请按照本指南并按照相反的顺序执行操作。
33等其他人完成本指南。
由衷感谢以下译者:
20%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
11条评论
Breaking apart the halves takes patience. Took 30 minutes. Mine was glued together like a tank, and it was not easy at all to separate the halves. Maybe JBL saw this post and doubled the glue to dissuade DIY fixes. Once I separated the halves, it was easy, but be prepared to get moderately frustrated in doing so. Also, don't get angry and try to force them apart, because from my experience, I do believe there is a high risk potential of cracking either halve if attempting to brute force the issue. Remember, patience is a virtue here. Lastly, you can get a good set of spudger tools at Harbor Freight Tools for cheap. They are actually called Wax Carving tools made in India of stainless steel. Excellent set to complete this fix, and I can see that they will be very useful in the future if needed. 10/10 for the author for the breakdown instructions. Cheers!
Follow these directions, Do not deviate from the path and you shall find Success awaits at journey's end.
one essential moment. when you're trying to disasemble a cover there is also one bolt under the battery socket! it not shown on step 5!
It is told in step 4, but not shown. I looked up this guide when I was stuck after step 5 lol
Btw I am the editor as of Saturday, 27/August/2016. Mine had 4 PH2 screws around the outside and 1 ph2 under the battery. I am not sure if that is how it always was
ion418 -
Hello, I am considering opening the Charge 3's fabric covers in hope that the sound would get better (I read that some frequencies are muffled due to the water proofing).
Any thought / experience on such outcome?
Olivier
Hi Olivier, I personally wouldn't do that on my device, as JBL probably picked their fabric to ensure dust protection along with quality sound. On the other hand, depending on the environment it is used in, removing the covers shouldn't necessarily ruin the device. I say go for it!
I'd be interested to know what your results were, if you decided to remove the fabric?
Hello, my JBL Charge has been having difficulty charging lately Currently it will not power up or charge. Are there any suggestions? Ie: open device, change battery, clean or repair mini USB port?
Any ideas here my charge 3 keeps turning on by itself and then it can't be turned off
After a while it goes off itself then boom on it is again
That start up sound on full volume at 2 am
Any suggestions other than bin it would be great thanks guys
My JBL Charge 1 had a similar issue. I was able to turn it off no problem, but it kept turning on buy itself randomly.
So I opened it up, unplugged the three power cables and plugged them back in. Also used a lens blower all over to remove any dust. Don't know if that did anything, but it's now fixed.
It takes some patience, because there's glue everywhere and the parts are tiny.
I'm no expert. It was a shot in the dark really, so I guess I just got lucky.
Better — a video.
