简介
使用本指南移除或更换小米 Mi 9 的后玻璃
重新组装设备时,需要使用“粘合剂”重新连接组件。
你所需要的
用预先切割的胶带或双面胶带固定新的后盖。
请按逆序重组你的设备。
安装后玻璃板后,施加压力几分钟以帮助粘合剂形成良好的粘结,例如将其放在一堆沉重的书本下。
维修没有按计划进行?尝试 基本排障方法。或者咨询我们的论坛 来寻求帮助。
将你的电子废料带到 R2 或 e-Stewards 认证的回收商。
请按逆序重组你的设备。
3等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
Hi Polly,
you can either buy pre-cut adhesive for your device/rear glass or use thin double sided adhesive tape you cut by yourself. For example you can use this tesa adhesive card.
Can you remove the fingerprint component from the old back cover? I just want to replace the cover as it is cracked and the fingerprint sensor is still working great.
Hi Dannoe,
the fingerprint sensor is glued to the back cover. To transfer the fingerprint reader you need appropriate custom cut adhesive to adhere it to your new back cover. You should be able to remove it by placing and iOpener for about 1 minute onto the back cover where the fingerprint reader is located (following the iOpener instructions) and carefully sliding an opening pick underneath the edges of the reader to separate it from the back cover. Be especially carefully in the area where the chip is located and avoid overheating it. Good luck with your repair!
