跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
如何维修烟雾器?
你所需要的
  1. 如何维修烟雾器?, 打开烟雾器: 步骤 1 中的图像 1,1
    • 打开烟雾器之前需要用螺丝刀拆掉图中的螺钉。
    • 拆掉烟雾器的外壳。
  2. 如何维修烟雾器?, 问题评估: 步骤 2 中的图像 1,1
  3. 如何维修烟雾器?, 烟雾器维修: 步骤 3 中的图像 1,1
    • 备齐必要的维修工具
    • 本例中,仅需要一根新的加热电阻丝和一个新的铲形接头。
    • 拆下加热电阻丝
    • 拆下铲形接头
    • 把新的加热电阻丝和铲形接头连接到它们各自应在的位置。
    • 加热电阻丝位于双金属器件的下方(图中看不清楚)
  4. 如何维修烟雾器?, 重新组装烟雾器: 步骤 4 中的图像 1,1
    • 简单按逆序操作上述步骤以重组烟雾器。
结论
重新组装你的设备,请反转以下步骤的操作顺序。
7等其他人完成本指南。
由衷感谢以下译者:
en zh
45%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
rjay
于09/29/12注册
233 声望
撰写一个指南
23条评论
My fogger heater is jam how can I clean it?
vishal_kishor777 - 回复
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Ember Leona - 回复
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
Giedrius Stasiulis - 回复
I would make a post on Halloweenform.com
Mad_as_a_hatter -
My fog machine is not pumping out smoke
Ohwaga Kerry - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 55
过去 30 天: 167
总计 63,609
