跳转到主内容
如何粘鞋底
你所需要的
  1. 如何粘鞋底, 如何粘鞋底: 步骤 1 中的图像 1,3 如何粘鞋底, 如何粘鞋底: 步骤 1 中的图像 2,3 如何粘鞋底, 如何粘鞋底: 步骤 1 中的图像 3,3
    • 将开胶的鞋底从鞋上拉开。
    • 用清洁布来清洁鞋身的底面。
  2. 如何粘鞋底: 步骤 2 中的图像 1,2 如何粘鞋底: 步骤 2 中的图像 2,2
    • 清洁鞋底与鞋身接触的表面。
    • 鞋子需要清除所有污垢并完全干燥后才能继续进行下一步。
  3. 如何粘鞋底: 步骤 3 中的图像 1,3 如何粘鞋底: 步骤 3 中的图像 2,3 如何粘鞋底: 步骤 3 中的图像 3,3
    • 沿鞋底的与鞋身接触的边缘薄薄的涂一层胶水。
    • 涂好胶水后请立即进行下一步骤。
  4. 如何粘鞋底: 步骤 4 中的图像 1,1
    • 将鞋底推回到鞋的原始位置。
    • 将鞋底鞋身一同按压30秒。
终点
24等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
团队
Michigan Tech, Team 1-19, Lauer Spring 2016 Michigan Tech, Team 1-19, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G19
1 名成员
创作了7篇指南
7条评论
Thank you! I have a pair of shoes of a brand i have never seen, Just love the uniqueness of them and want to make them wearable.
Francisco M. Yruegas III - 回复
I have not yet attempted to repair the sole separation on the completely separated soles of the lady's boots I was hoping to. I was looking for guidance here. Yet even the instructions on the glue package tell me it needs 8-12 hours of pressured curing to correctly complete this repair. So if you meant to leave the last step of this tutorial to be “Hold the shoe and sole together for 30 seconds" which is the last step available gor viewing, then at least explain the contradiction.
Stephen Carman - 回复
I imagine its hold for 30 seconds, the leave for 8 to 12 hours.
Stuart Cox -
Any gluing procedure almost always is more successful when clamped, weighted for at least 12 hours!
what’s the hurry? you can’t use it anyways! This includes leather, plastic, wood, fabric or whatever!
jim.
james daly - 回复
I would estimate a job like this a little longer. No need to rush this part, it's the most important asset to footwear. Its responsible for the function/use, comfortabilty, form, strength and durability. So this must be done efficiently and effectively.
I advise pulling apart the soles until you meet where they are joined. Starting from this point is best. Just observe the faces of the two soles and clean away any dirt and debris. Be sure to allow the footwear to dry before continuing with adhesive. Use a strong and durable adhesive to bond the two soles together. Be careful as some adhesives tend to swell after curing and this can cause discomfort and render footwear useless. Completely cover the face of both soles. Dont worry about excess just wipe away as you squeeze them together and hold. Be sure to clamp footwear soles for the duration of the curing process to prevent and leaks cracks. Then finish off with water/stain repellent to repel moisture and increase the life of the glue repair.
ChanDuhMan - 回复
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 152
过去 30 天: 695
总计 156,066
