简介
如果你的 Mac 没有连接安装了macOS的存储设备,或你的启动盘已损坏,电脑启动时会闪烁带问号的文件夹图标 ,然后关机。
按照本指南使用互联网恢复模式启动你的 Mac,并使用磁盘工具,时间机器和 macOS 安装器。
只有在2009年后发布的苹果电脑可用互联网恢复模式。如果你的电脑在2010-2011年发布,你需要更新至最新的 macOS,或通过 EFI 和 SMC 固件升级启动互联网恢复模式。
从恢复菜单中,你可以从时间胶囊恢复你的备份,重新安装 macOS,获得在线帮助,或者使用磁盘工具格式化或者解决任意连接的储存设备的问题。
59等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
40条评论
Oh, I’m so sorry! I forgot to specify: internet recovery mode is only available on newer Apple computers. I’ve updated the intro now, sorry for the confusion!
So a mid 2009 computer won’t have internet recovery mode?
I bought a Asgard (seems operates from HongKong) 2TB NVME PCIe M.2 SSD that I installed into mackbook pro 15in mid 2015 with sintech adapter for conversion to MacBook AHCI controller. The disk utility does not show this SSD. Later I installed in same way another Sabrent SSD 2TB it worked fine.
What might have gone wrong in the fist SSD. Could that SSD itself faulty or incompatible? any fixes available?
Two main reasons:
- You aren’t pushing deep enough your new ssd drive into the slot. Please reopen your mac, unplug the battery connector and push the new ssd to a fashion position.
- Your are missing the Alt/Option key. Please make the full shorcut: Alt+Shift+R.
