跳转到主内容
如何把iPhone X 強制重新啟動
你所需要的
  1. 如何把iPhone X 強制重新啟動, 如何把iPhone X 強制重新啟動: 步骤 1 中的图像 1,1
    • 短按音量增加按鈕(1)
    • 然後短按音量減小按鈕(2)
    • 按鍵時間必須短暫
  2. 如何把iPhone X 強制重新啟動: 步骤 2 中的图像 1,1
    • 完成後,按住側面按鈕,直到出現蘋果標誌(3)
终点
126等其他人完成本指南。
由衷感谢以下译者:
fr zh
100%
Dominic Wong正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
13条评论
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - 回复
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - 回复
good share. thanks.
MelissaR - 回复
What is the other way?
sa sas - 回复
will it delete all data from my iPhone?
_TR0xuu_ - 回复
添加评论
浏览统计数据:
过去 24 小时: 44
过去 7 天: 396
过去 30 天: 1,550
总计 348,042
