跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
如何把iPhone 8 強制重新啟動(如何强制重新启动 iPhone 8 【simplified Chinese】)
你所需要的
  1. 如何把iPhone 8 強制重新啟動(如何强制重新启动 iPhone 8 【simplified Chinese】), 如何把iPhone 8 強制重新啟動(如何强制重新启动 iPhone 8 【simplified Chinese】): 步骤 1 中的图像 1,1
    • 短按音量增加按鈕(1)(短按音量加按钮)
    • 然後短按音量減小按鈕(2)(然后短按音量减按钮)
    • 按鍵時間必須短暫(按键时间必须短暂)
  2. 如何把iPhone 8 強制重新啟動(如何强制重新启动 iPhone 8 【simplified Chinese】): 步骤 2 中的图像 1,1
    • 完成後,按住側面按鈕,直到出現蘋果標誌(3)(完成后,按住侧面电源按键,直到出现苹果标志)
    can’t get it to hard reset, using those steps! ugh. it only brings up the slide to power off option
    steph g - 回复
    brings me to slide to power off option every time.
    steph g - 回复
    Doesn’t work for me neither, either showing the slide to power off, or getting the apple logo but no reset option - simply saying the phone is disabled as if there was no reset
    Amit Lieberman - 回复
    If you push 1, then 2, then the side button and the slide appears, keep the button down and click on the X (cancel) button, then the logo will appear. Now it has reset!
    Carl Schultz - 回复
终点
37等其他人完成本指南。
由衷感谢以下译者:
fr zh
66%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
9条评论
Very helpfully, thanks!
user7 - 回复
helpfully, thanks!
pat trixia - 回复
All that happens for me is getting the slide to power off..never a reset. About to throw the phone.
Cheri Hogan - 回复
Same as above. Slide to power off and not able to slide. It is frustrating.
nick_nic112 - 回复
I suggest you learn to read. hold power until apple sign appears. you need to keep holding it. not sliding it to switch off.
Gurin Jeimuzu -
Wow - that was an insulting comment. I also had the same problem & I can read quite well. I am not sliding off either - just holding the power off as per instructions and the apple logo never appears. I have held it for a very long time, and only the slide power off appears. Your procedure does not work for me either.
Just watched a video someone else posted. Press the Volume Up & Volume Down button really quickly as smarty pants instructed. But - instead of holding the side button until the apple logo appears, you only hold it for 10 seconds and let go - then the Apple logo appears.
Elaine - 回复
Lots of people have this issue, but of course stupid and ignorant people like Gurin will blame the customer. I had the same issue and no luck with all google articles and even youtube videos that show the proper way and speed to do it. Take it to an apple repair center, they have a “special method” that they wouldn’t disclose to me to force it into recovery mode.
chosenbydestiny - 回复
Putting comments like these just shows how closed off from him/herself that person is. Instead of creating rapport, he/she are one of those who feel compelled to prove something. compensating for something, eh?…
Wonderful for you doing the work, but your attitude is what will get YOU and your work noticed and appreciated.
I am having similar issues as above and i hope you can provide an answer, and if not, at least a solution. Otherwise, this article might as well be removed.
I pressed the up volume, released.
Pressed down volume, released.
press and hold power button on side=the slide on/off comes up as i kept holding. Nothing happened and the screen dimmed before it went back to home screen.
Any of the new firmwares caused this or am i missing something?
Thank you
iLan Azoulai - 回复
merci beaucoup, très pratique
André Djoubdouna - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 244
过去 30 天: 785
总计 65,915
