简介
使用本指南从 Steam Desk 的 BIOS 中打开它的电池存储模式。
在打开 Steam Desk 进行内部维修之前,Valve 建议启用电池存储模式以提高安全性并将设备损坏风险降至最低。
如果你是为了长期存储Steam Deck而不是维修它而打开电池存储模式,请在打开该模式之前,将你的电池放电(或者充电)至50-60%之间。
处于存储模式下,你的Steam Deck将不会响应点击开机键的任何操作。要退出存储模式,将充电器插入你的Steam Deck。
要退出电池存储模式,请将你的 Steam Desk 插入充电器。
维修没有按计划进行? 尝试一些 基本故障排除,或向我们的 Steam Deck 社区寻求帮助。
77等其他人完成本指南。
由衷感谢以下译者:
85%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
13条评论
I thought that this mode is also for when you not going to use your Steam Deck for more than a week. And if so, what is the percentage of battery you should leave the Steam Deck with before putting it in storage.
Uzi Batish - 回复
The help page valve provides via the device indicates not to engage the mode above 80% state of charge.
From my personal experience with other devices and the state of charge the device ships at, I'd recommend something around 50% to 60% as a desirable storage point for best battery life during long-term storage
Lithium batteries usually needs to be stored at around 50% SOC, however when you want to store such a battery, you also have to keep in mind the self discharge rate, and the fact that once over-discharged (even through self discharge) a lithium based battery could be dead and should never be recharged as it could burst in flame. That's why 60-65% is a good choice, as it will allow you to store it a lot longer without reaching over discharge state.
Help! I followed these instructions to a T and also replaced my SSD following that guide to a T and now I'm presented with this message:
"Default Boot Device Missing or Boot Failed. Insert Recovery Media and Hit any key
Then Select 'Boot Manager' to choose a new Boot Device of to Boot Recovery Media."
I don't know what any of this means and I can't find a single straight answer anywhere.
You need to install an OS.
See Valve's instructions - https://help.steampowered.com/en/faqs/vi...
Rich -
