跳转到主内容
华为P9 Lite扬声器更换
你所需要的
  1. 华为P9 Lite扬声器更换, 后盖: 步骤 1 中的图像 1,2 华为P9 Lite扬声器更换, 后盖: 步骤 1 中的图像 2,2
    • 从底角开始,使用三角撬片打开后盖。
    • 逆时针方向操作,一个接一个地小心地撬开塑料卡扣。
    What could you use instead of an opening pick??
    Alfredo - 回复
    Like, could a guitar pick wor? Or anything else?
    Alfredo - 回复
    A guitar pick will also do.
    Tobias Isakeit -
    what can still be used besides guitar pick
    Tarshia Thompson - 回复
    I had a hard time to open the back cover by opening pick. Then I used little, really little knife at first, and I continue to opening back cover using opening pick.
    Andy B - 回复
    Heating up aroud the finger sensor to loosen the square adhesive tape ..
    Hishamchohan - 回复
    If you do not have any picks, You can also adapt an old credit or utility card by cutting it in to thirds. Then with some fine emery or sand paper, rub a sharp point on the one edge of the card. This will help you get access to the clips that hold the rear cover on. The one i did yesterday had quite a lot of adhesive around the edge & around the finger print sensor. Another tip with an old credit card is to cut it in to narrow strips to insert in to where you have separated the cover from the frame to stop it getting stuck to the adhesive again.
    gazza667 - 回复
  2. 华为P9 Lite扬声器更换: 步骤 2 中的图像 1,1
    • 后盖下方有粘合剂,可将其固定在电池上,顶部装有金属板。
    • 小心右侧的柔性电缆。
    • 拧开三角撬片,将后盖拉开,并将其从粘合剂上松开。
    Most of the adhesive is around the fingerprint cell and on the battery itself. You can slowly pull the back cover from its side but make sure not to break it. Push the mediator or a longer piece of plastic under the back cover to slowly destroy the adhesive.
    Nicolas Combaret - 回复
    Slowly, slowly wins the day. Nicolas is right and comes off a charm. The most nerve wracking part of this longish repair.
    John Nordstrom - 回复
  3. 华为P9 Lite扬声器更换: 步骤 3 中的图像 1,1
    • 当后盖没有粘合剂时,你可以完全用手将其弹出。
    Hi! Im so sad! At the begginig of the operation i ve broken the white seal/connector that in one side is connected to the board and the other side is "glued" to the battery. Can someone help me? how can i solve this?? There is no image displayed on the screen. but there is vibration, sound, notifications... can someone help me please???
    Diogo - 回复
    What you broke is handling the NFC, and doesn’t have anything to do with the display. You probably damaged the ribbon right below the battery, since that’s what links the display to the motherboard.
    Polaris -
    Oups ! L’antenne NFC était solidement collée à l’intérieur de la coque et j’ai donc déchiré sa nappe en ouvrant la coque. Heureusement, je n’utilise pas les fonctions NFC et, à part cela, tout a l’air de fonctionner normalement.
    Michel Orban - 回复
  4. 华为P9 Lite扬声器更换, 扬声器: 步骤 4 中的图像 1,3 华为P9 Lite扬声器更换, 扬声器: 步骤 4 中的图像 2,3 华为P9 Lite扬声器更换, 扬声器: 步骤 4 中的图像 3,3
    • 在手机的底部卸下这些螺丝:
    • 3个2.9 mm 菲利普斯十字 #00螺丝
    • 4个3.8 mm 菲利普斯十字 #00螺丝
    • 现在你可以把扬声器给拿下来了。
结论
若要重新组装您的设备,请按照相反的顺序完成这些步骤。
12等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,588 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
3条评论
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - 回复
Same problem here. Any help?
fabio9999 -
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 10,204
