你所需要的
使用一个吸盘将屏幕拉出缝隙,在缝隙内插入拆机片,注意,拆机片不能划太深,否则会将指纹排线割断。
将拆机片沿手机四周划开,拔吸盘(稍用力,要慢慢来),吸起后盖。
把后盖向右翻开,一定得小心,翻开角度太大可能会扯断排线。
要重新组装你的设备,请按逆序操作。
要重新组装你的设备,请按逆序操作。
37等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
22条评论
Can the antenna cable (black thin one) be reused?
hi, when you replace a faulty battery does the screen needs to be changed as well even though the screen is fine?
Normally if you can remove the battery, without damaging the screen then just replacing the battery should be ok
Harvey -
I had to replace the back cover as well as it was also damaged. You will have to try it and see if the adhesive is still strong enough to stick.
Harvey -
