Mate 20 X 5G 配置:
7.2英寸的 1080 x 2244 分辨率OLED触控屏
八核麒麟980芯片组,搭配8 GB内存
256 GB内置存储
巴龙5000多模5G基带
4200毫安时的电池,支持SuperCharge 2.0
后置三摄:4000万像素ƒ/1.8主摄,2000万像素ƒ/2.2超广角和800万像素ƒ/2.4五倍变焦摄像头
前置摄像头在“水滴”中间,后盖有一个我们自动忽略的警告标识。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
10条评论
OOO first comment! By the way, Are Mate 20 X and Mate 20 X 5G screens cross compatible? They both have the same dimensions so I am intrested
By the looks and the make of both phones the displays should be compatible. We haven’t checked yet since we don’t have a Mate 20 X at hand. Check a users teardown of the Mate 20 X here.
Hi, Is It Possible to Fully Remove the Fingerprint Sensor from the Back Cover? I will buy another back cover, because my broke ..
Hi Felipe, it’s indeed possible to remove the fingerprint sensor from the back cover (pry it off with an opening tool—a little heat helps). Be careful with the attached flex cable and small ZIF-connector and the extension cable that is also glued to the back cover.
I guess not since the battery connector is in a different spot and the Mate 20x battery cable would be too short. See here for comparison: 华为 Mate 20 X 拆解
i have a mate 20 x that only chargers at .19 amps does not turn on , I have replaced the mid board
can any one help ? has any one had this problem before
I hope X-ray picture is also shown in this teardown page.
Osamu Akaki - 回复
