简介
使用本指南来更换华为 Mate 20 Pro 中的破旧或没电的电池。
打开华为 Mate 20 Pro 将``损坏设备上的防水密封''。如果你不更换粘性密封圈,则手机将正常运行,但会失去防水功能。
如果电池膨胀, 采取适当措施。为安全起见,在拆卸手机前,请使电池放电至25%以下。如果电池在维修过程中意外损坏,则可降低发生热危险的危险。
尽管无需卸下带充电端口的主柔性电缆即可取出电池,但我们建议这样做以避免损坏周围的组件。
你所需要的
要重新组装设备,请按照相反的顺序进行操作。用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。
为了获得最佳性能,请''''校准 你新安装的电池:将其充电至100%,并继续充电至少两个小时。然后,使用它直到由于电池电量不足而将其关闭。最后,不间断充电至100%。
将你的电子垃圾带到R2或e-Stewards认证回收商。维修没有按计划进行吗?请查看我们的论坛以获取故障排除帮助。
12等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
17条评论
I have tried this with two new batteries now. I believe the device was water damaged by plugging the charger in while there was moisture in the port. The existing battery works but doesn't fast charge and gets very hot when charging, the battery also drains extremely quickly. Everytime insert a new battery the phone just get stuck in a boot loop, bringing up the Huawei powered by android screen before restarting, I have also replaced the charging port in hopes that may of been damaged and was causing the issue but this didn't work either. Any suggestion?
Excellent Step by step guide thank you
