简介
遵照下述指南即可为任天堂Switch更换内置电池。
Nintendo Switch 使用 JIS 螺丝,但是使用 Phillips 螺丝刀也是可以的。注意不要磨光螺纹。iFixit 的 Phillips 套件可以兼容 JIS 式螺丝。
卸下屏蔽板时,您需要更换屏蔽板和散热器之间的导热膏。 一般的散热硅脂并不适用于填补散热管和屏蔽罩之间较大的缝隙,使用K5 Pro这类粘性较大的硅脂更为合适。
本指南以及我们出售的一些零件,均适用于2017年发售的原版任天堂Switch以及2019年发布的续航增强版机型(型号分别为HAC-001和HAC-001(-01))。
Switch上的一些螺丝可能上的很紧且容易滑丝。这些JIS规格的螺丝有时候采用#00十字螺丝刀或者#000十字螺丝刀可能会更好。如果您感觉螺丝要发生滑丝,请放慢操作速度。
由于电池紧紧地粘在机体里,需要使用粘合剂清除剂才能取出电池。
拆机之前,要放电至电量低于25%。一旦发生意外碰撞,电池可能会起火并(或)爆炸,放电可以使意外发生的可能性大大降低。
如果电池已经鼓包,请不要用热风吹你的Switch。用滴管或注射器将高纯度异丙醇(浓度90%以上)注入到电池下方来弱化粘合剂。鼓包的电池非常危险,所以如果你打算亲自动手,最好戴上护目镜,并且格外小心。若是还不清楚该怎么下手的话就交给专业维修人员吧。
你所需要的
视频概述
使用 JIS000 螺丝刀,或者 iFixIt PH000 螺丝刀取下用于固定后面板的螺丝:
一颗在主机顶部的散热器出口旁,长度为2.5毫米的螺丝
两颗在主机底部的充电接口两侧,长度为2.5毫米的螺丝
150等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
50条评论
Can anyone confirm that Switch will NOT work with the battery removed or dead (dead as in once it’s totally non-functional as all lithium batteries eventually are, not dead as in just discharged but the battery works).
PSP works with the battery dead or pulled, as far as I know DS, 3DS, Vita and Switch do NOT, which is a gigantic design flaw.
Yes. The battery of my Switch has been wearing down over some time, to the point where I had to charhe the device for some hours to even activate it - it isn't functional without a working battery.
I would highly recommend against keeping dead batteries in any system, as this can cause damage to the motherboard of the device. If you experience your Switch randomly turning off while its battery is dead, immediately seek to get the battery removed or replaced.
While it is considered rare, dead batteries can sometimes reverse in polarity when its voltage is too low. This can damage the motherboard or other components unexpectedly.
Reboot -
Why can't you reuse the switch's battery?, if I'm just replacing the shell of the switch and have to move the battery why can't I reuse the battery in the new shell?
Good question!
For safety reasons, we strongly discourage people from reusing a battery once it has been removed. Bending a lithium-ion battery even slightly can create uneven spots between the thin layers inside the battery. The battery may function fine for awhile, but over time and charge cycles, the uneven area can wear down faster, eventually resulting in an electrical short. The battery would fail, swell up, and possibly catch on fire.
