简介
用这条指导来交换上部机身。
一些交换上部机身的步骤中可能包括对触摸板以及电池的操作。如果有这种情况,跳过18至44的步骤。
这条指导需要拆除散热铁。在你重新安装散热铁之前不要忘了按照我们的的 涂散热膏指南来涂散热膏。
你所需要的
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
移除电池。
幸运的话,你可以用你的手慢慢地将粘合剂撕下来。
否则,用一点粘合剂去除剂将每个粘合剂部分浸泡2-3分钟,然后用撬片或其他工具将其刮掉。 这可能需要相当多的工作,所以要耐心。
擦拭残留的粘合剂去除剂,花一些时间让MacBook Pro风干。
校正 您新安装的电池: 充电至100%, 并保持充电状态至少2小时。拔掉电源并使用电池供电。当您看到低电量警告时,保存您的工作,继续使用您的笔记本直到低电量自动睡眠。静置5小时后一次将电量充至100%。
如果您在安装新电池后发现任何不寻常的行为或问题,可能需要重置MacBook Pro的SMC。
若要重新组装你的设备,以逆序方式执行这些说明。
57等其他人完成本指南。
由衷感谢以下译者:
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
8条评论
Hey I need to replace my track pad for sure, but would anyone know if the circuit board on the backside of the track pad controls the keyboard? or where the hardware is that controls the keyboard? My mouse and keyboard arent working due to water damage and apple wants 750 for a part thats less then 100 dollars. Any insight would be much appreciated!
@andrew how do you re-assemble the iOpener-removed battery? Just lay it in-place and re-heat it all with the iOpener? Can the adhesive be re-used?
I ended up reassembling with the remaining glue on the battery and trackpad cover panel. I used a hairdryer to attempt to reactivate the glue since my iRemover sprung a leak. The outside-most cells are loose - oh well :). Maybe I'll open it up and tape them down.
Well done Andrew!!! I followed this guide and surprisingly everything is good. The tech at the Apple store tried to convince my daughter that she fried the logic board + keyboard by getting water into it. (It was a month past the warranty so we didn't argue.) But she swears she never got any liquid near it. I didn't see any obvious signs of moisture when I opened it up. Based on other comments on other sites, it seems more like Apple has shipped some defective keyboards for at least some MacBook models.
that’s exactly what is happening with me now!!! apple is trying to convince me that there is a liquid damage exactly on the I/o board in my mackbook pro early 2015. At first the battery isn’t charging and they said that they will change the top case including keyboard and battery, five days later which is today the call me saying they discovered a liquid damage on the I/o board and the price will be changed from 200 hundred pounds to 325 pounds. I definitely refused and suspected them. now I took my MacBook back again and looking for another solution. it works fine with the power cable. so any idea would be highly appreciated.
many thanks
sofian
Sofian -
