简介
这是一般的拆卸,主要用于更换LCD /屏幕组件。 这是我在iFixit上的第一个指南,所以请对我温柔以待。 :) 如果您正在寻找液晶显示器组件,我们这里有货,从加利福尼亚州出快速发货。
你所需要的
要重新组装您的设备,请按照本指南的相反顺序进行操作。
90等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
48条评论
Does the digitizer snap in? Or will I need adhesive to install my new digitizer?? Other phones that I have replaced the digitizer I needed adhesive, but I know some just snap in. I'm hoping this is one of those that just snap in.
With this phone, you would need new adhesive. I would recommend using the 2mm Tessa 61395 tape ( Tesa 61395 Tape )
So is it even possible to actually just replace the digitizer? Because it seems like in getting it out I took the lcd with it?? is that "always" the case???
The digitizer may be built into the LCD panel it self, it's not uncommon. If that's the case, no, it would not be possible to replace just the digitizer. And the cost to difficulty ratio would be rather low
