跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
三星Gear S3 后盖更换指南
你所需要的
  1. 三星Gear S3 后盖更换指南, 后盖: 步骤 1 中的图像 1,1
    • 倒置您的设备, 使您的手表正面朝下, 背面朝上。
  2. 三星Gear S3 后盖更换指南: 步骤 2 中的图像 1,2 三星Gear S3 后盖更换指南: 步骤 2 中的图像 2,2
    • 用Y00螺丝刀将四个4.2毫米螺丝卸下。
    Y0 passte bei mir deutlich besser als Y00
    Alex Fi - 回复
    Did you use iFixit tools? I just checked and I believe Y00 is correct. Y0 slips too easily. My test was with the Y bits from the Pro Tech Toolkit.
    Nicholas Dudde -
    I too had to use an Y0 screwdriver (from Ifixit 64 bit driver kit....). Y00 just don't grip, may be some batches of the watch used different screws??
    regislefeuvre - 回复
    One screw just doesn't want to move, any suggestions/tips how to remove it?
    Slartibartfast - 回复
    Problem solved: after 2 times of careful WD40 application and blunting the Y00 a bit it came of with a lot of patience.
    Slartibartfast -
    I also had a problem with one of the screws and flipping to Y0 worked for that one.
    Jeff Lambert - 回复
    Yo use Y 0.6 y anduvo perfecto!!
    Gustavo Zarate - 回复
    Yo use Y 0.6 y anduvo perfecto!!!
    Gustavo Zarate - 回复
    The tool kit that came with my battery was a Y1.5 and worked perfectly
    jnewsom22 - 回复
  3. 三星Gear S3 后盖更换指南: 步骤 3 中的图像 1,3 三星Gear S3 后盖更换指南: 步骤 3 中的图像 2,3 三星Gear S3 后盖更换指南: 步骤 3 中的图像 3,3
    • 将金属撬棍沿着后盖与框架之间的缝隙插入。
    • 使劲将后盖从手表的框架上翘起。
    • 事实上这一步确实需要花费一些力气。 如果可以的话, 您可以用短撬棍替代金属撬棍, 这样或许让这一步轻松的多。
    • 这一步的操作会使防水层损坏。
    Il est plus facile et moins domageable pour le joint de commencer par ouvrir le cache de connexion situé à coté de l’axe du bracelet long. On peut alors glisser la broche sans détériorer le joint, qui est plus éloigné du bord à cet endroit.
    Yann Richet - 回复
    I’m pretty sure the seal is equally far away from the edge on all sides.
    Nicholas Dudde -
    This was the hardest part. I did use thin flat head screw to dismantle it. Using the metal spudger felt like impossible due to its thickness.
    Mariusz - 回复
    Did using the screwdriver damage the case in any way? I’d recommend being careful using a tool with smaller surface area as that will apply more pressure at the point of entry. As the guide states, a Jimmy may also be used instead of the spudger.
    Nicholas Dudde -
    Anyone know where to buy the replacement gasket after breaking the seal between back cover and watch? Thanks.
    Jyon - 回复
    Not sure if it's a gasket or some sort of sealant paste/gel. Just took my case off, and the gasket seems intact (fused to back cover of the watch. Quick search for waterproof sealant yielded lots of possibilities - don't know which one to choose. Can anyone with experience provide advice?
    Alan Lawee - 回复
    most things I have seen online say use an RTV like permatex black sealant. pretty available at like autozone or o'reilly or walmart.
    Steven Betts -
    Ma questa guarnizione impermeabile si puo sostituire ? Come controllare se si è danneggiata? Come evitare che entri acqua dopo averlo aperto ?
    ant.beneduce - 回复
    La photo montre une ouverture coté bouton mais pire coté car l'ouverture abime quand même le couvercle en plastique sur la face la plus visible : essayer plutôt sur les autres cotés
    stoufbook - 回复
    Il est préférable d'utiliser, si possible, un outil adapté pour l'ouverture des boîtes de montre.
    Avec précaution, le joint n'est pas trop abîmé. Il est distendu. Possibilité de le couper et de le réajuster correctement.
    Fabrice - 回复
    I have used a the Jimmy and I didn't need to do any force at all
    Carlos Rafael Ramirez - 回复
    Que puedo usar para poner en la tapa y cambias el sellado ya que se me arruinó.
    Quiero que vuelva a ser hermético.
    Gracias
    damian levi - 回复
结论
请严格遵循这份指南, 以便您拆修并重组您的设备。
17等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
Lazy_Lazy_Man正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
William Hurty
于10/08/18注册
2,674 声望
创作了3篇指南
团队
Cal Poly, Team S15-G2, White Fall 2018 Cal Poly, Team S15-G2, White Fall 2018 的会员
CPSU-WHITE-F18S15G2
4 名成员
创作了34篇指南
10条评论
How do I ensure the watch will be waterproof again?
Robert Simpson - 回复
Doesn’t sound like anything a careful application of RTV can’t handle. It can be found in small squeeze tubes at most auto parts stores, where it might be sold as ‘liquid gasket’ or something similar. You can also get it at hardware stores in large tubes meant to be used in caulking guns.
If the original gasket still looks good, no cracks or breaks in it after you remove the cover, I’d wager it will still be water proof after you put it back on. If it’s damaged, I would try to remove it entirely, and likewise, if the replacement cover doesn’t have a seal, you would want to apply some RTV or similar sealant. Ideally, I would use a syringe for this. In the US at least, you can buy needles at a pharmacy without a prescription, you just have to ask for them at the pharmacy counter. Suck some RTV into the syringe, and apply it carefully on the sealing surfaces of the cover. Put the cover on before the RTV dries so it mates to the surfaces, give it about an hour to cure, and it should be water proof.
Jonathan Sherrill -
Will the watch be waterproof again once the new back is installed!??
Paul O'Regan - 回复
The back case of the watch contains an integrated rubberised o-ring.
Force is best applied by taking the band off and working at the edges adjacent to where the band meets the case.
There are small lips here where the thin metal Jimmy can be used to pry the case off with patience and low force by alternating between each end of the case.
The metal spudger tool recommded by this guide is the wrong tool for the job. The ends are far too thick.
Jimmy used: Jimmy
Ben Russell - 回复
I lost 1 screw for the back cover. Where can I get a replacement? I measured the screw. Body Ø.045” x Length .133” x Head Ø.072. Metric conversion probably screw size M1.2 x 3.5mm lg. Any help would be greatly appreciated. Thanks
Bailey Major - 回复
Is it worth to replace the back cover if Samsung says there is water damage as well as a cracked back? Would I need to replace the battery too?
Clay Churchill - 回复
If you use your prying tool by the screw heads, you won’t ruin the o-ring and can just keep it in place and reuse it
cruckman1974 - 回复
Jyon - 回复
I changed the back glass on my Samsung Galaxy gen3 frontier and know it won't charge it charged before I changed it why
jason heckman - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 148
总计 27,220
