简介
本指南介绍如何拆卸和更换 Samsung Galaxy S9 + 的电池。
打开Samsung Galaxy S9 Plus会损坏设备上的防水密封。如果不更换粘合剂密封,手机将正常工作,但会失去防水功能。
在操作之前,请将电池放电到25% 以下。如果你的电池膨胀,采取适当的预防措施 并且不要加热手机。
在重组时你需要重新涂抹粘合剂。
你所需要的
视频概述
在开始之前,请关闭手机。
将加热的 iOpener 应用到手机的长边,以松开后玻璃下方的粘合剂。使用 iOpener加热至少两分钟。在拆开过程中,你可能需要多次重新加热并重新施加 iOpener,以使粘合剂足够温暖以便切割。
要重组设备,请按逆序执行以下说明。
如有可能,在涂抹新的粘合剂之前,打开手机电源测试你的维修。
为获得最佳性能,请校准新安装的电池:将其充电至100%,并继续充电至少两小时。然后,使用它直到它因电池电量不足而关闭。最后,不间断地充电至100%。
请将你的电子垃圾带到R2或e-Stewards认证的回收商。
修理没有按计划进行?查看我们的 论坛以获取故障排除帮助。
要重组设备,请按逆序执行以下说明。
52等其他人完成本指南。
由衷感谢以下译者:
87%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
6条评论
Just be careful to remember to try phone parts (such as, battery recharging OBV, Fingerprint sensor…) before closing with the new cover.
Also remember to attach the Wireless card before doing the battery test otherwise the phone will say that can’t charge because the phone is too cold.
That’s because on the wireless charger module there is the heat sensor.
Missed one of the most important parts: Where and how do you install the adhesive pieces? There are a lot of them and the linked article doesn't even come close to explaining it for this phone.
Good instruction, I was successful replacing the battery however I accidentally damaged the fingerprint scanner cable because the image showed above is mirrored and I sliced too far in on the wrong side.
Also, a brief note on which adhesives can/should be removed before reassembling would be very helpful.
Re-assembly is not as straightforward as using the reverse order as above as you need to remove all the old adhesive and re-apply the adhesive supplied with the kit. It's not obvious where the upper and lower adhesive parts go - the following ifixit youtube is very useful at working out where and how to re-apply the adhesive:
How To Re-Apply Adhesive to Your Samsung Galaxy Phone! - YouTube
