简介
你也可以学习到如何去修复你的Note3。
例如你想修复一个屏幕破碎的Note3,看完本指南后,你可以尝试在网上买到一个新的屏幕,然后自己动手修复。(译者提醒:note3单独拆解还是有一定困难的,不建议轻易尝试。)
你所需要的
将设备关机后,拆下后盖,并取出电池。(如有sim卡或sd卡则一并取出)
由于Note3采用了可拆卸式电池设计,这使得拆卸过程简单且无需任何工具。
此处可看到主板上有七处排线连接处,使用塑料撬棒将其分别拆开,这时就可以取出主板了。
使用撬棒,小心并适当用力地撬开USB小板,因为小板是用胶粘住的。
Use a heat gun or hair dryer to loosen the glue if you need to. I worked a few different angles to slowly work it up. I also work mostly around charge port bracket because it’s the strongest point. I don’t want to break the circuit board or bend it too much.
使用适合的螺丝刀撬出振动电机。请注意,振动电机是粘在底盘上的,并且电源按钮是与振动电机在一起的,取出时请注意不要损坏电源按钮等。
Very, very difficult. There is a small rectangle near the 4 contact pads; use this to help pry the adhesive backing off of the frame to reduce the chance of damage. Whatever you do, DO NOT attempt to pull loose using either the motor or the power button legs. These will tear and will require you to purchase a new one. Alternatively, save yourself some time and buy a new one to begin with if you’re doing a repair.
三星 Galaxy Note 3 的拆解到此结束。
Just used this guide to replace my screen, thanks!
由衷感谢以下译者:
92%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
40条评论
is it possible to use a Sprint Galaxy Note 3 USB port on a T-Mobile Galaxy Note 3?
It will fit, but the antenna are different. The phone will not work properly: the wireless reception will be worse.
I did exactly that and I haven't noticed any difference at all. My phone works and charges perfectly now, and all it took was 12 bucks and a little patience. Good luck!
If single sim it same
mmm why no repairability score?
Can you include how to remove the camera lens from the middle chassis/plate? I saw somewhere it is removable from the middle plate..
I got a Note 3 Live Demo Unit and well i did some research and i found out that the only thing different is that it lacks the antenna, do you know if is possible to buy it and just put it in? will the phone work after that? or do I need to buy a whole new mmotherboard with clean IMEI?
Yep... the IMEI is not registered on the Live Demo unit. Plus the software on it will need changing
Oh plz help, its been a while Im using note 3 N9005, Now I figure it out that my RAM capacity reduced excactly 1Gb and it shows me 1.423 Gb Ram :( antutu benchmark confirms this too :(( is there any way to replace my Ram?
Do u use high or
In the process of replacing just the glass on my sprint galaxy note 3, I nicked up the copper color foil at the top of the phone. It is just under the earpiece and looks like it hooks to the LCD screen. I was wondering is it is possible to replace that cable and where could I get one. The digitizer and the LCD screens were still in working order when i started to tear off the old glass. Please help.
Would the housing for the T-Mobile and at&t version be interchangeable? For example, could I order the n900a in frame LCD/Digitizer for a T-Mobile note 3 (n900t)?
Or go as far as ordering the lte version (n9005) I believe it is GSM as well?
Hello, I have a Galaxy Note 3 purchase from overseas (Dubai). how do I find know part to order (USB/Charging port) for my phone if it wasn't purchase from AT&T/T-Mobile/Sprint /Verizon. model (SM-9005). will the part for the Sprint/Verizon work on my phone? or i will have to special order the part. Thanks W56
Just same as note 3 n9006
How can I get the heat shields replaced, the ones that are on the back of the motherboard. I lost mine :(
I have replaced charger port /mic twice and mic still won't work any suggestions?
Mic doesn't work. Cleaned everything, replaced charger part mic is on twice. Any suggestions?
so i have note 3 SM-N900 , i wanted to change the board on it so i can have 4G internet. If i buy the board and change it will their be any issues i should be aware of? The board is like 60$, it sates that it is unlocked and Europea version, n9005 32 gb.
Thank you this was some good help for my phone
My note 3 was charging, fell off table and now is dead. When i plug it in or try to power on however i hear a single pop and subtle feedback from speaker. Anybody seen this before? Wondering if it's my usb board only or the logic
where is the graphics card located on board?
good evening.
could you pleaze tell me where is the graphics card located on samsung galaxy note 3 N9005 board?
thank
where is the graphics card exactly located on motherboard on Samsung galaxy note 3? plx help me
can i replace my defective note3 at@t motherboard with note 3 n9005 motherboard?
Julws erer - 回复
can i replace my defective note 3 at@t motherboard with note 3 n9005 motherboard?
Julws erer - 回复
What is the L shaped line underneath the battery in my Galaxy note 3 and can it be damaged? I have noticed a small dent on one part of the larger L shape.
What your means is charger lex cable
is this possible to change rom from one note 3 motherboard to another note 3 motherboard, actually my phone motherboard is dead and i want my data back,,or there is another way to get back my data
is it possible to replace internal memory chip in new motherboard to get back data
A question .I am having very low gsm signal. Do you propose any fixes? I think it is the antena circuit.Any ideas please?
kiriakidis - 回复
thanx for the help; I am scared to death to do the repairs but the phone is dead so what does it matter.
