跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
三星盖乐世S7后摄像头透镜替换
你所需要的
    • 如果你只替换后摄像头的玻璃透镜的话,请按照这个教程操作。
    • 在此插入翻译如果你要替换整个面板,跳过这个步骤并且按照下一个步骤操作。
    My lenses did not come with with adhesive on either side
    Joshua albano - 回复
    None of the links work
    tripmine67 - 回复
    Thank you, you just saved me $80. I took it to a place that gave me a quote of $80. I bought the kit from Amazon.com for $10, we already have a hair dryer at home. Because I was trying to be very careful, the whole process took me 15 minutes. Very helpful. So thank you.
    Don Johnson - 回复
    I took the broken glass off, removed adhesive and placed tape over the camera to make sure there was no additional glass inside. As stated in video the can cause additional problems with focus. Good thing I did because additional glass came out through out the day.
    Joshua Silbernagel - 回复
    • 按照这个更长的步骤来替换装在后壳的面板和摄像头透镜。
    • 在此插入翻译如果你按照这个教程操作,你需要新的胶水来重新固定后盖。
    I did ut. It worked perfectly untill i realized my camera could not focus anymore... i ordered a new spare part and will try to remove the replacmenet one to clean it. I hope it doesn't come from the lens...
    Baptiste Le Sueur - 回复
终点
33等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Evan Noronha
于02/05/15注册
223,460 声望
创作了168篇指南
12条评论
THANK YOU SO MUCH for the first video!!!
Grace Arnott - 回复
Follow up... What happens if there is a bit of dust? Is there a way to get rid of it?
Grace Arnott - 回复
I ordered 2 lens replacements and neither one of the lenses have adhesive on either side do I need to buy some kind of adhesive sepratly or should 1 or these sides already have it on there
Joshua albano - 回复
same thing with mine josh albano i just plopped it in and am going to hope for the best.
John Biello - 回复
How can I make sure I don't get my replacement glass in backward.....because my focus is still gone. I'm devastated because I purchased this phone specifically for the camera to take pictures to upload to my eBay account. I worked for almost a full year before I could afford to buy this camera phone and I purchased it outright from straight talk. I own my camera and it is not insured. I followed your directions to replace my lens and now I'm worried I might have it in backward. How can I tell if the lens is in place incorrectly? By the way, my phone has never been dropped. It has been protected by an otter box since its purchase. My lens seemingly self-imploded. Just the strangest thing. Other than the lens, my camera doesn't have a scratch on it! Thank you for any help. Molly
Molly Azbell-Thompson - 回复
Mine shattered too with no impact occurring, I just picked it up today at work and the glass cut my finger. I see that there are some claims out there like ours, Molly.
victoriad1219 - 回复
This was so easy and saved me more $50-$90! Except there's a lot of glass dust under the new lense. I tried to get as much out as I could. Is it worth trying to get the new glass off and knock more out? I did buy two pieces in case I messed up.
Dara Abrams - 回复
That might be a good idea, I'd worry about the glass dust possibly spreading? I'd recommend canned air to blow out the pieces (watch your eyes!). You might also be able to use some sticky putty to reach in there, of course you risk getting the putty stuck in the camera assembly, so try the canned air first!
Sam Goldheart -
where or how do i buy the lens? can’t find it in the parts
Renegade Zed - 回复
What do I order to replace the lenses glass only.
Confused as to what to order.
Perry Hirsbrunner
William Hirsbrunner - 回复
Do I have to remove benzel on back of camera to get the glass out?
Thanks
William Hirsbrunner
My right glass is broken, camera still works perfectly, I'm perplexed 🤔 I'm glad but..
foodexpedite - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 78
总计 152,836
