简介
换电池最难的部分就是撬开屏幕了,如果你撬开了,接下来的任务就简单很多了。
如果你的电池鼓包了,您得小心一点鼓包电池的危险之处
为了你的安全,您需要在拆机之前将电池用到25%以下。
这样操作将降低拆机时电池发生意外的可能性。
你所需要的
90等其他人完成本指南。
由衷感谢以下译者:
100%
wangliuyu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
26条评论
Thanks a lot for your contribution! It worked perfectly.
Kyuhwa Lee - 回复
I follow the instructions but it said the battery is too slow
Charge the battery for at least a few hours. If the battery does not charge, double-check all connectors, especially the interconnect cable. Does the phone react to a charging cable? If not, something may be broken between the USB port and the motherboard.
It honestly took an hour to get the back cover off, and then another hour to take the rest apart and put it back together. But this guide was useful.
Thanks so much for this guide. Worked out great!
