简介
使用本指南更换一加 Nord上破裂的屏幕。
如果框架变形,请务必更换框架,以确保新屏幕能够正确安装,并且不会因压力不均匀而损坏。
拆卸手机之前,请将电池的电量放电至25%以下。如果不小心将其刺穿,电池可能会着火和/或爆炸,但如果放电,则发生这种情况的可能性要低得多。
注意:本指南指示你仅在更换屏幕的同时将原始框架和母板留在原处。但是,此手机的某些替换屏幕已预先安装在新的框架(也称为机架)中,这需要非常不同的过程。在开始本指南之前,请确保你具有正确的零件。[br]
重新组装设备时,你需要更换粘合剂来重新连接组件。
你所需要的
如果可能的话,在安装新的粘合剂并重新密封之前,请先打开设备并测试维修情况。
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的零件或从新零件上取下胶粘剂背衬。
要重新组装设备,请按照逆序进行操作。用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。
固定新屏幕的最佳方法是在屏幕背面粘贴一张定制的双面胶带。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的论坛寻求帮助。
24等其他人完成本指南。
由衷感谢以下译者:
90%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
14条评论
So essentially the greater part of the guide is only necessary because OnePlus decided to have the display connector at the back of the phone rather than at the front under the display? What a poor choice repairability-wise on their side, very disappointing! Otherwise great guide.
Hi Nikola, yes, this is troublesome! Indeed, you have to make a few moves until it is possible to remove the display. Unfortunately, there is no easier way.
Yes!, I had the same problem, I spent all day trying different ways to get out like three pesky screws. :( Any tips from anybody? I scoured the internet for a few hours, tried a few different things already but any help would be much appreciated!
Hi @Tee Jay, to reassemble your OnePlus Nord and install the new screen, follow the steps in this guide in reverse order.
