跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
一加 一电池更换
你所需要的
  1. 一加 一电池更换, 移除后壳: 步骤 1 中的图像 1,3 一加 一电池更换, 移除后壳: 步骤 1 中的图像 2,3 一加 一电池更换, 移除后壳: 步骤 1 中的图像 3,3
    • 移除sim卡托
    • 使用塑料工具,小心将后壳与机身分离。 千万小心sim卡槽附近以及其他脆弱位置。
    • 您可能在开壳的时候遇到些阻力,因为有些卡扣藏在手机内部边缘位置。 别担心,移开一个卡扣然后按着一个方向绕圈就能打开后壳。
    • 从上到下从左到右逆时针顺时针,一旦绕了半圈就可以用手移除后壳。
    • 别急着现在就拆下电池,请按照我们后面的指导来进行操作。 不正确的操作可能会使电池受损。
    It doesn't mention you have to remove SIM tray first.
    pawel - 回复
    I used the #0 for the rear panel screws. The #00 is too small and will slip, stripping the screws if you're not extra careful.
    anonymous 2668 - 回复
    where can i buy the battery??
    Shaun Davis - 回复
    Has anyone answered this? I am looking too.
    Elie Daou -
    They sell it on here, although I found mine on eBay.
    Roger -
    Aliexpress for $9 (original)
    David van Ballegooijen -
    The last three hidden screws are a !&&* of a time consumer to remove. probably you would need only a certain type of tweezers - I got stuck at midway and now I cannot get go have my phone detect the sim card either probably because the six screws are removed. I can now turn the phone back on but with no service or wifi connections are detected. This phone is a disaster!
    Manan Shah - 回复
    Ivdid that too but son in law found I had reinstalled sim card in backwards or upside down.
    wildcat75666 -
    Where did you buy the micro USB piece? Thanks a lot!
    Davide Rota - 回复
    EBay. I bought new battery cause old ibe was dead would not charge. Just ordered new cables fit 9.00 something free shipping. Anyway hope this fixes problem cause new battery did not fix problems.
    wildcat75666 -
    I was able to open going from the microusb slot and working my way around. The corners are tough, though.
    Roger - 回复
    in my phone the battery was glued with double sided adhesive tape, only on the right side. I pried the left side up first, and carefully removed the battery. to lift the battery I used first used a suction cup(?) followed by a plectrum like tool to lift te battery, and keep it lifted
    Eelco Busch - 回复
    A word of caution: the back panel is harder to remove than you might think. Especially because you may be removing the *screen* by mistake. When you have a "grip" with the tool make sure the metallic border is not coming off with it, and when you have removed enough to be able to lift the panel, make sure it isn't attached by ribbons - in that case you've been removing the screen. A good idea is to gently press your finger nail against the weak plastic located between the back and the SIM slot, and going up and down and sideways until you hear a click. Then you can start from there with the opening tool. As recommended be very gentle around the SIM slot.
    Menahem Julien Raccah Lisei - 回复
    Where do I get the plastic opening tool?
    Julie Hejducek - 回复
  2. 一加 一电池更换, 移除主板保护壳: 步骤 2 中的图像 1,3 一加 一电池更换, 移除主板保护壳: 步骤 2 中的图像 2,3 一加 一电池更换, 移除主板保护壳: 步骤 2 中的图像 3,3
    • 使用镊子,移除塑料塞子。
    • 一旦隐藏的螺丝出现了之后,使用 PH #00 螺丝刀移除3个 3.175 mm的螺丝。
    • 使用 PH #00 螺丝刀移除剩余的6个3.175 螺丝。
    The plugs are annoying to open for the first time. They're shaped like little pegs, but I was able to poke at them with screwdrivers enough to open.
    Roger - 回复
    the best spot to start prying the cover open is at the cable outlet for the power/volume buttons (careful not to dameage the wires)
    Marius137 - 回复
    A needle works best to remove the plugs.
    Stan Barton - 回复
    I second this. I used a sewing pin and the plugs came out in no time!
    Liam Ong -
    Be careful not to displace the rear camera when replacing the motherboard cover.
    Liam Ong - 回复
    when I lifted the motherboard cover the battery cable stuck on it so that I lifted both, the plastic cover and the cable - step 4 below was not necessary to perform. Be careful!
    Rene Hommel - 回复
    anyone know what is the 6 orange screws in step 2 are called?
    e.g. M2 x 2
    I lost some screws.
    So where can I buy some replacement of these screws?
    Tyler Durden - 回复
  3. 一加 一电池更换: 步骤 3 中的图像 1,1
    • 使用塑料开启工具,温柔地撬动黑色盖子,从设备上移除。
    At the top right of your device you see a white dot. That white dot is the warranty sticker. You need to take off that sticker in order to get to the screw that lies underneath. Then unscrew that screw. Otherwise you will not be able to pry off this cover.
    Anke - 回复
  4. 一加 一电池更换, 移除电池: 步骤 4 中的图像 1,2 一加 一电池更换, 移除电池: 步骤 4 中的图像 2,2
    • 在我们取下主板盖后,我们注意到电池上连接着黑色的带状物并安装在逻辑板上。
    • 使用撬棒,小心地开始将电池从黑色带状物对面的一侧提起。 请注意,高档胶带将电池粘贴在其位置上,请保持谨慎和耐心进行此操作。
    • 这种电池没有被包裹在硬壳中,所以它是柔软和有韧性的。 拆卸期间必须小心,以免造成永久性损坏。
    This took a ton of force to remove from the adhesive!
    Also I was able to take off the cable before removing the battery.
    Roger - 回复
    Is it OK to use the battery if I bent it during removal? I had to 'iron' it flat, but I think it might still be useable...
    Henry Annand - 回复
    the best way to remove the battery is to lever the left side up from the bottom and remove it from the glue with an old credit card
    Marius137 - 回复
    Do this! it comes up very easily this way. All the adhesive is on the right side.
    Daniel ONeill -
    Great suggestion with a card to remove the battery!
    Jeff Mack -
    Thanks for this trick saved me a lot of time
    George P -
    I second Dangerous Picture's suggestion. I found it very helpful to remove the ribbon from the dock (it was easy to do) before trying to remove the battery.
    Stan Barton - 回复
    on my phone extensive use of glue was concentrated on just one side (right hand side). Not impossible to remove, little tricky
    Rene Hommel - 回复
    I mistakenly removed the battery with force, and the back peeled and brought out smoke, seemingly like it's gonna explode. Help !!!
    warys Moreno - 回复
  5. 一加 一电池更换, 移除电池排线: 步骤 5 中的图像 1,3 一加 一电池更换, 移除电池排线: 步骤 5 中的图像 2,3 一加 一电池更换, 移除电池排线: 步骤 5 中的图像 3,3
    • 一旦电池被取出来,我们就会使用一个黑色撬棒来撬开电池,并将电池连接线从其底座上卸下来。 成功!
    • 你可以把电池先拆下来,这样会容易些。
    For step 4, the connection to the battery should always be done as soon as possible so after removing the back plate to the board would be ideal.
    Otherwise, very thorough so far!
    Duc - 回复
    Thought I was going to snap my battery in half but patience and slight pressure did the trick.
    Also agreeing the battery should be disconnected as soon as possible.
    Rasmus Beck - 回复
    From where do I procure a new battery for it?????????
    Roderick Edric Chandra - 回复
    très bon tuto ,aucun problème si vous suivez la procédure ,bravo et merci
    antoine v - 回复
    There are several connectors to the motherboard. In the picture above, one connector above and, below the screw thread, three more connectors. Be careful to reconnect any connectors accidentally disconnected while disconnecting / removeing the battery. In my case the connector shown at the top of the row came unconnected.
    Jörg Thiesemann-Bihn - 回复
    salut, pour moi le connecteur à la nappe était collé au cache en plastique qui couvrait la carte mère … mais le reste s’est bien passé.
    Merci pour le tuto !
    Didaf Wazir - 回复
    Thanks Buddy, I replaced battery of my one plus one and when I switched it on, touch was not working. It was heart sinking panic moment...Then I came across https://forum.xda-developers.com/oneplus... post, simple trick of sliding piece of paper below battery solved and infact improved the touch response. Thanks !
    Radhakrishna Shetty - 回复
    Kifch nikmandha
    asadzoya388 - 回复
    When putting in the new battery, the battery ribbon cable did not line up with the dock on the motherboard, on the replacement battery I ordered from iFixIt. I was able to carefully peel back the foil covering ribbon cable, align the cable, then press the foil back in place. Now, everything seems to be working.
    I P - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
198等其他人完成本指南。
由衷感谢以下译者:
en zh
88%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Javier Cruz
于09/22/14注册
2,265 声望
创作了3篇指南
团队
USF Tampa, Team 3-3, Brown Fall 2014 USF Tampa, Team 3-3, Brown Fall 2014 的会员
USFT-BROWN-F14S3G3
3 名成员
创作了20篇指南
36条评论
The Apple iPhone sim ejector is not long enough to work on an OPO. A paper clip is a better option.
stephenacook - 回复
There will be a compatible battery with one pin OnePlus
Gendarmetal Rock - 回复
Successfully accomplished, thanks to your clear instructions. One note: the adhesive on my unit was applied in about a quarter inch strip along the right underside of the battery as you view it from the back. Peeling up the left side allowed me to reach and release the adhesive on the opposite side with the spudger or knife blade.
That Guy - 回复
Thank you! I use a slim (but not sharp) butter knife to nudge the battery out slowly by poking the adhesive tape along its length. It was a bit unnerving because I was afraid of damaging the soft battery. Worked out in the end.
Benoit Hogue -
One note to add is that the original battery connector's top was glued to the motherboard cover. I had to remove the battery before I could successfully sepearte the 2. My phone is still working and I'm charging it right now! :)
Thanks for the very detailed guide.
Benoit Hogue -
How can I tell if the charging port or the battery that is damaged?
Ang Wei Ming - 回复
After doing this my screen no longer works. It's just a black screen whether I use the old battery or the replacement.
Terry Atkinson - 回复
Fixed the black screen issue by taking the cover off and then checking all connections and putting back together. All good now. Hardest part was to get the cover off. Starting from the sim card port worked eventually.
Terry Atkinson -
anyone knows where can i buy a good quality battery? i dont want a cheap replacement...
Moti Dorfman - 回复
I just got mine from this Ebay seller: http://www.ebay.com/itm/162062594869. It is an original battery, as far as I can tell.
Ordered it on Monday, received it on Friday. It took me about 30 minutes to replace the battery and it seems to work.
ireneverweij -
Hi everypone! Recently i bought the new original Oneplus One battery from this site, in few weeks i'll make an update.
http://www.ebay.com/itm/Original-BLP571-...
Alex Mendez -
Thanks it was verry useful and at the end succesful. With this tutorial i was verry confident.
Jean-Marie Wallut - 回复
I just very proudly followed these instructions and my phone switches on again \o/
Now the touchscreen is unresponsive :-( what did I do wrong?!
Dud - 回复
Also- is the old, broken battery hazardous? What should i do with it?
Dud - 回复
Burning. Flushing down the toilet is also a popular choice.
Alex -
I am looking for the new battery to replace old one in my Oneplus one. Can anyone help me, where can I get the genuine one or at-least a good one?
me_paracom007 - 回复
Good manual! Be careful the battery cable is attached to motherboard cover. Don't tear it off right away. Loosen the motherboard cover and SLOWLY and CAREFULLY lift it to see whether yours is attached too. Also get 1-2 plastic cards like credit cards to lift the battery from the tray. Mine was glued on the right side if you look at the battery with phone lying on the table face down. Make sure to discharge your battery before removal.
Slava - 回复
My phone only comes on when it's plugged to power. Could this be a battery problem? How can I get a new battery in Nigeria?
Chioma Ogbonna - 回复
Great post i have been using one plus one since its release in india still i have that phone no lagging no any issue great phone ever at that price .
Thanks on your marvelous posting! I certainly enjoyed reading it. I will remember to bookmark your blog and will eventually come back from now on.Also Look for <a href="http://www.cabs2go.in/tours/mumbai-to-ma... style="text-decoration:underline;" target="_blank" >Mumbai to Mahabaleshwar taxi</a> I want to encourage that you continue your great writing, have a nice day!
Prabhash Chandra - 回复
Absolutely flawless. I followed the guide with the recommended battery and some simple tools. It worked like a charm at the very first trial and in 10 minutes. THANK VERY MUCH, SIR.
Manuel Gómez - 回复
my oneplus one works only when charger is plugged in…turns off immediately or reboots when unlugged…could this be a battery issue…
Venkat Sudheer - 回复
Since there have been none of these batteries in stock for a long time, I found a Spanish website that sells them quite cheap. They appear to be official OnePlus batteries. Quite handy for any peeps in the EU :) www.impextrom.com
Bruno Pascoal - 回复
Excellent guide, replaced with the recommended battery. Charged, and is up and running….
boobear97 - 回复
Bought a new battery for USD 9.50 via Ali Express. Lots of suppliers. Thanks to the clear and concise instructions I completed the battery replacement in no time, using a sharp knife to pry things apart and a plastic throw-away knife to help further. Put things back together and the OPO works as a charm. Just goes to show that OnePlus were environmentally friendly back in the old days. Nowadays you throw the phone away when the battery is dead, USD 500 (OP 5T) for a replacement phone. And thanks to the guys at ifixit, their efforts help us keep the world clean.
Rene Boers - 回复
Réussi. Merci Javier !
didier.vanbogget - 回复
DONT BUY from this seller. battery not work well https://www.ebay.com/usr/xiongdoudou17?_...
peter h - 回复
I've had my Oneplus One for nearly 2 years now and while I'm very happy about the hardware and even the software (still on Cyanogen), the battery is starting to become really weak. It used to last way longer with a single charge than it does now and I want to replace it
i think battery is dead because i play many unblock games on my mobile
ana smith - 回复
Since the day I met him, he knew that today
One day, my memory is filled, surrounded by pictures of me surrounded. Struggling forever in a sentence, "now what to do?...... Play Game: basketball games
famitofu - 回复
Everything worked like a charm from the first time. Very clear and detailed instructions. Thank you!
Sergiu Negara - 回复
Great, I peeled off the repaired battery, exactly what you told me, thank you. and now the battery is back
'''temple run 3'''
goalken46 - 回复
e.g. M2 x 2
Tyler Durden - 回复
Worked like a charm. Like others have said, most difficult part was removing the back cover. The adhesive on the old battery was a little tough as well. My battery cable was also stuck to the back cover. Connecting the new battery cable was pretty easy, just needed to look closely to make sure aligned to snap in. Many thanks!
Sean P - 回复
Your post is very meticulous and impressive for me, I hope to get more good posts. shell shockers
bearpu1994 - 回复
Super Anleitung Danke
Udo Schütt - 回复
thanks for the guide. Battery cable was sticking to the motherboard cover. Like comments before mine also had a glue strip on the right underneath the battery. So tilting it up from left works, be careful not to break it.
Mathias Paech - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 58
过去 30 天: 246
总计 212,907
